How to install cams?
well you have to take the valve cover and timing belt cover off first. After that you MIGHT be able to slide the belt off by undoing the tensioner, if you cant then you must take the crank pulley off. From there take the 10 ( i think) bolts the hold the cam cradle (for lack of words) on. Take cam out, put in other, and reverse the process and double check timing.
