Is there a tool for these?
Old Nov 23, 2008 | 06:12 PM
Sivic90's Avatar
Icon2 Is there a tool for these?
I was wondering if there is a tool to take these rivet things off? I want to re-do the wheels and would like to take them off to do it. Also, Is there somewhere you can buy all new rivet bolt things?
Thanks for your help
Old Nov 23, 2008 | 06:22 PM
cjames235's Avatar
those are not rivets they are 12-point bolts......... assuming they are actually 3 piece that is......... you should just be able to take a 12-point socket and break them loose
Old Nov 23, 2008 | 07:05 PM
H22Ej1's Avatar
Shenanigans
if they are real 3 pc be careful when putting them back together, ive heard horror stories of constant leaking when putting them back together
Old Nov 24, 2008 | 07:13 PM
JNocon's Avatar
^^^Ya, that happen to me before w/ my RH Type C's. Put it back w/ criss-cross pattern and use silicone to seal it on the barrel.
Old Nov 24, 2008 | 08:04 PM
octaneaccord02's Avatar
I just use a 8mm or 9mm socket. Easy to remove but I prefer a professional wheel repair store to put them back together. They need to be loctite or silicone back on at a certain torque. You will have fun removing them rivets, its time consuming when you have no air tools. always criss-cross.
Old Nov 25, 2008 | 12:42 AM
frm_808's Avatar
in other words star pattern. never tighten/loosen the bolts that are right next to each other..
just think of it like ur takin off ur lug nuts for ur rims...
and yes i would think torque is very important when coming to these rims or any 2-3 piece rim for that matter
Old Nov 26, 2008 | 10:07 AM
r.wright's Avatar
first of all look on the back of the rim and tell me if the there is a nut that holds that bolt in place..
if not than those are simple beauty rivets and can still be found new..
just bring an 12pt socket to them GENTLY and test em out:
example:
http://cgi.ebay.com/ebaymotors/30-Rivet-screw-pieces-for-Konig-Remembers-Wheels_W0QQcmdZViewItemQQcategoryZ42614QQihZ009QQi temZ190269284832QQrdZ1QQsspagenameZWDVW
Old Nov 26, 2008 | 10:10 AM
r.wright's Avatar
or: http://www.prestigewheel.com/mainRivets.htm
Old Nov 26, 2008 | 01:56 PM
Joon Joon's Avatar
could new bolts like that still be bought??
Old Nov 26, 2008 | 06:00 PM
old man neri's Avatar
Yes. McMaster-Carr seems to carry them. However, be careful as the ones in the link below are not 'graded'.
Link
Old Nov 26, 2008 | 06:28 PM
Joon Joon's Avatar
wat about ones with the indentation in them??
Old Nov 26, 2008 | 11:04 PM
r.wright's Avatar
http://store.blackforestindustries.com/wheels1.html
found these awhile back as well
Old Nov 27, 2008 | 05:10 AM
Joon Joon's Avatar
will those fit?? seem a bit long.. i dont know.. need new rivets/bolts though
Old Nov 27, 2008 | 04:38 PM
r.wright's Avatar
good luck. those are the only three links i have found any types of new bolts.
the all out kid
Mar 19, 2009 06:20 PM
16yroldekownr
Jun 17, 2008 06:09 PM
oem_CD5
Jun 14, 2007 12:44 PM
BadEH2
Aug 17, 2004 07:15 PM
ALF
Jul 7, 2001 10:31 AM
