Options for D16Y8 replacement
Old Nov 23, 2008 | 02:15 PM
greasemonkee's Avatar
Default Options for D16Y8 replacement
I have an obd2 EX auto here and the owner toasted the internals. A rebuild would not be my first choice due to the condition of the cylinder walls/valve guides and machine work required.
Thhis thing is an auto and am investigating the possibility of anything else that may be a practical replacement. I had my eye on the jdm d15b, but I don't even know if you can run a jdm ecu for these obd2 datalink emissions tests.
Does anyone have any info or links to the info I'm after? I'm an obd1 guy so a little ignorant in this area.
Old Nov 23, 2008 | 02:47 PM
94EG8's Avatar
Seagull Management
Have you considered an OBD2 SOHC non Vtec D15B or OBD2 SOHC Non Vtec ZC? You should be able to run both with a stock Y7 ECU, they wont run as well as they would with the correct ECU, but a Y7 should be close enough to work ok. Theres not much else available unfortunately for OBD2 SOHC JDM engines. Although if you look at this link http://sunrisejdmmotors.com/engine_d...p?id=19&page=2 at least one importer is selling Y8s, I'm not sure where they're getting them from though.
Old Nov 23, 2008 | 02:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
see if anyone has a y7 they are getting rid of, and mini me swap it? i have done that on a manual ex. not an auto.
Old Nov 23, 2008 | 03:14 PM
tx_ej8_49's Avatar
^ Word. I had a rod knocking y8 and swaped it for a y7 block with a rebuilt y8 head. Runs good for a single slam. 96 obdII ex 5spd, not auto.
Old Nov 23, 2008 | 03:25 PM
jeff79's Avatar
not to spam but can some please epain what a mini me swap is..
Old Nov 23, 2008 | 03:29 PM
94EG8's Avatar
Seagull Management
SOHC vtec head on a SOHC non vtec block. run by SOHC vtec ECU.
Old Nov 23, 2008 | 03:33 PM
jeff79's Avatar
so all you would have to is swap out the heads and ecu.
Old Nov 23, 2008 | 04:00 PM
b16_sol_707's Avatar
There's a little more to it than that.
Old Nov 23, 2008 | 04:46 PM
Mr. Badwrench
if the car is already a vtec, you are golden, just have to take out the oil squirter before you put the head on.
JDMDC2 88
Jan 3, 2012 05:03 PM
Rcp
Nov 1, 2007 08:20 AM
ComputerJLT
Feb 7, 2005 09:32 AM
showtymers619
Aug 4, 2004 09:29 PM
EE_Chris
Jun 12, 2004 02:43 PM
