Starting problem: 89 Crx Si w/ dohc zc swap.
Old Nov 23, 2008 | 01:49 PM
kojack_0's Avatar
Icon3 Starting problem: 89 Crx Si w/ dohc zc swap.
alright, after 3 months with this motor, it runs strong, it pulls, and its very reliable [until today]
on the way to work, driving normal and not speeding, my motor suddenly shuts off.
i didnt hear any noises at all, my radio was off and my window was cracked open. the car was warmed up to normal idle [750-800 rpms] before driving it.
i pull over and try to start it again, it wont start.
checked fuses and grounds, it wont start.
no engine light or cel or any battery/brake light on.
check the ecu on my friends car and its good.
i have half a tank of gas.
my friends and i tried to push start it and it almost started, but nothing.
i feels as if im not getting spark, so i replaced the cap and rotor.
still nothing.
has anyone have that kind of problem before?
i need help, my crx is the only transportation i have and i need it running asap.
thanks in advance.
Old Nov 23, 2008 | 01:54 PM
kojack_0's Avatar
bump anybody?
Old Nov 23, 2008 | 02:22 PM
Mr. Winky's Avatar
fuel main relay under the drivers side of dash. replace it and you should be fine.
Old Nov 23, 2008 | 02:28 PM
Justin91CRXSi's Avatar
Check your distributor, those are bad about going bad
Old Nov 23, 2008 | 09:39 PM
kojack_0's Avatar
tomorrow i will be replacing the main relay and distributor with new cap/rotor.
ill see where that get me.
im pretty sure i didnt blow my piston rings, or valve train, etc. that motor was slightly rebuilt, and was running very healthy.
so if its not the dizzy or main relay, what else could it be?
Old Nov 23, 2008 | 11:57 PM
shirecain's Avatar
check for spark if no spark then check all fuses under hood and dash most probobly the dist. coil or ignitor. buy rebuilt one at autozone and it will come with a life time warranty
Old Nov 24, 2008 | 07:42 AM
kojack_0's Avatar
can somebody confirm if a obd0 crx si distributor will work on a zc?
or if the coil from a crx si distributor will work on a zc?
Old Nov 24, 2008 | 07:54 AM
89civichb's Avatar
You need the same distributor as the 89 Integra.
Old Nov 24, 2008 | 03:05 PM
kojack_0's Avatar
what coil will work with a dohc zc distributor?!?
Booz
Mar 26, 2012 09:37 PM
9.3.S.I.L.U.D.E.
Jun 1, 2010 11:34 AM
94gsr_teg
Dec 12, 2007 11:42 AM
zcrxsir88
Nov 9, 2003 04:33 PM
crxdevelop
Mar 10, 2003 12:32 PM
