where to have a leak down test done in toronto?
Old Nov 23, 2008 | 10:33 AM
itr1235's Avatar
Icon6 where to have a leak down test done in toronto?
i had an engine rebuild done 30,000 km ago and the i can see white smoke coming out the exhaust and also leaving the black soot on the bumper. i had the rings changed and the intake and exhaust seals changed. thank you
Old Nov 23, 2008 | 01:46 PM
AW's Avatar
AW
Where did you get this done? There are not many places in Toronto that have the equipment to do a proper rebuild?
Old Nov 23, 2008 | 06:52 PM
itr1235's Avatar
i had the block sent out to be honed, it got replaced with OEM standard size rings that was recommended by the machine shop and he replaced the valve seals. as for assembly my meachanic and myself along with the service manual assembled the engine
Old Nov 24, 2008 | 03:19 PM
ScottBell's Avatar
White smoke or light blue smoke? Soot on the bumper is from fuel smoke (black)
Old Nov 24, 2008 | 04:50 PM
hondapowerb16a2's Avatar
by a compression tester and do the leakdown yourself. its really not that hard. there is tons of info about it on the net. if your not comfortable with that pretty much any auto repair shop can do it. and the general rule is white is coolant/water black is rich/fuel and blue is oil. coolant could be the headgasket and the black soot could be the coolant in your exhaust loosening up and blowin out the carbon build up in your exhaust.
Old Nov 24, 2008 | 08:22 PM
itr1235's Avatar
i look back in my rear view, while driving i can see the smoke i cannot tell if is light blue or white. i will check on the bumber. and yes there is black soot on the bumber. the headgasket along with all the other gaskets were replaced with OEM. the coolant is green. thanks
mike:
Jul 10, 2015 02:51 PM
SIK IN DA HED
Jun 7, 2006 05:23 PM
finest_GSR
Jan 29, 2006 06:32 AM
ek2k
May 25, 2005 01:17 PM
petrv
12
Jul 14, 2003 06:33 AM
