Needs Help with a Swap
Old Nov 21, 2008 | 10:30 AM
ATK_Tae's Avatar
Default Needs Help with a Swap
Hi guys, I'm Daniel and new to all this.
I have a 94 Honda cx with the pos motor that has gone bad. So i have an D15b with a p08 cpu coming. I just need to know a few things about the swap and i can't find it on your site..
could someone pls help me with it and pls stay on subject and dont tell me to get something else
Old Nov 21, 2008 | 11:19 AM
b16_sol_707's Avatar
you should be able to drop it in without having to modify anything. Just use the stuff from the old motor, it will all swap over to the new one.
Old Nov 21, 2008 | 11:26 AM
K i l l a B e e.'s Avatar
you should tell us what you need help with.
Old Nov 22, 2008 | 02:13 PM
ATK_Tae's Avatar
I just need to know about the o2 wire and how to wire up the vtec.... pls help
Old Nov 22, 2008 | 02:58 PM
94EG8's Avatar
Seagull Management
You wont have to do anything with the O2 sensor. The CX is a 1 wire setup, so is the P08 ECU. For the Vtec wiring you will need to run 2 wires, plus a ground. Please see the pinout below.
Old Nov 22, 2008 | 03:08 PM
teamworxek9's Avatar
^ that should do it
Old Nov 23, 2008 | 04:54 AM
ATK_Tae's Avatar
ok i thought the cx was allready wired for vetc from the firewall to the ecu?
Old Nov 23, 2008 | 05:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Only the 1992 Cx is, along with all other 92 Civics, regardless of trim level.
From 93-95 the CX, DX, and LX all have to be wired for VTEC, which is only two wires, so it's not a big deal.
Old Jan 8, 2009 | 02:52 PM
ATK_Tae's Avatar
Default Re: Needs Help with a Swap
ok the motor is in and running great.. about a half mile up the road i blew the tranny so what is a good trany i should get with this swap
Old Jan 8, 2009 | 02:55 PM
HondaGuy951's Avatar
ok, how exactly do you "blow a tranny"?? anyway, the best tranny for you would be a 92-95 si tranny sure it's not the clutch you wore out? you sure it's the transmission itself?!
Old Jan 8, 2009 | 05:00 PM
94EG8's Avatar
Seagull Management
You break the diff pin, differential blows a hole in the side of the case.
Old Jan 9, 2009 | 01:35 AM
ATK_Tae's Avatar
ok well i pulled up to a stop sign and went to take off and it felt like it just poped out of gear like i didnt have it in 1st all the way and i just pushed in the clutch and just put it in gear and nothing... just a sit and spin...
Old Jan 9, 2009 | 06:25 AM
94EG8's Avatar
Seagull Management
Did you look at it at all yet? The axle probably just popped out (it wont come right out and fall on the ground, it just backs out about an inch or so)
j12ball
Jan 11, 2006 04:48 PM
allmotorej8
25
Jun 18, 2005 02:12 AM
Lysawy
Oct 21, 2002 08:15 PM
B_CRUZ!
Nov 22, 2001 12:58 PM
