HELP! what line goes into this vacuum nipple.
Old Nov 20, 2008 | 11:50 PM
K i l l a B e e.'s Avatar
Default HELP! what line goes into this vacuum nipple.
can someone tell me what line goes into this vacuum nipple? If i block it with my finger, the idle drops wayyy low, so i know it has to hook up somewhere.
Old Nov 21, 2008 | 03:46 AM
Tiger_Si's Avatar
the EVAP sensor hose goes there.
Old Nov 21, 2008 | 05:04 AM
Echo7847's Avatar
Correct evap purge control solenoid.
Old Nov 21, 2008 | 08:43 AM
thank you for the responses. So if i dont have the purge solenoid i can just block it off correct. I dont care about emission purposes.
Old Nov 21, 2008 | 09:04 AM
R.Kelley's Avatar
correct..make sure you dont have a purge valve hooked up either.
Old Nov 21, 2008 | 09:19 AM
Larkin W.'s Avatar
You said nipple
Old Nov 21, 2008 | 01:46 PM
John Z's Avatar
Originally Posted by Larkin W.
You said nipple
so did you :D
Old Nov 21, 2008 | 01:56 PM
damn. when i put a vacuum cap over it, the car dies. what gives. i dont have a purge solenoid connected either. The car runs fine at idle, until the CEL for the o2 sensor kicks in, then it idles at 1500. I think im just gonna leave the vacuum open to the air and buy a new o2 sensor.
Old Nov 24, 2008 | 05:41 AM
twentyhurtz's Avatar
? hmm, when i switched my gsr IM to a skunk 2. i just took the vac line that went to my butterflys and put it on that nipple, and its been working perfect for over 2 years now. Then about two weeks ago my IACV went bad and i put a new one on yesterday and somehow bumped that vac line off, well my idle fluxd from 1-2k back and forth, then i noticed the line, put it back on, but now i am stuck with a 1500 idle too, i can't figure out why though cause normal idle for me has always been 850 or so.
tgkaotic
Oct 3, 2012 09:21 PM
Maldito X
Jun 16, 2010 05:50 AM
almostjdmeg
Jan 31, 2010 05:43 PM
90Rexx
Mar 11, 2009 05:59 PM
MadVtak
Oct 8, 2007 10:52 AM
