f22b with p28?
i am planning on doing an f22b swap into my eg. I have a p28 that im gonna send to phearable to get chipped for the swap. i have been doing some research and found out that in order for this to work right i will have to swap pins a6 and a11.
on some of the threads that i have read some people have ran them without swapping and others say you have too. Thats where it confuses me.
my questions:
what exactly do they mean by swapping pins? Do they mean switching them around?
if i send it to get chipped with an f22b basemap will i still have to swap pins?
If i dont swap pins will the car run like crap?
any input is appreciated
my questions:
I'm not familiar with this swap at all, but I can tell you that swapping pins is simply pulling specific wires from the ecu plugs and switching them to a different position. In this case, you pull A6 (6th pin on the A connector), pull a11(the 11th pin on the A connector) and switch them.
ecu pinouts http://ff-squad.com/technet/wiring.obd1.htm
ecu pin removal http://ff-squad.com/tech/wiring/obd1.pin_removal.jpg
thanks for the replies guys it really helped. After doing more searching i have found out that in an accord you do have to switch the pins. My eg is a vx with a p28. I still dont get why you would have to switch the pins on a civic. It does have egr and i know that for the o2 i have to convert to 4 wire.
would i be able to run my p28 without changing around wires?
i did a f22b1 swap in my eg civic i did not swap any pins out. i used the civic engine wiring harness and just plugged in chipped p28 worked fine.need any help i will help as much as i can
delslowhonda
Apr 29, 2006 03:38 PM
