Tial Wastegate & Boost Solenoid Fitting Kit
$145 Shipped (Red/Blue Fittings & SS Hose)
$150 Shipped (Red/Blue Fittings & Black Pro Lite Hose)
Comes with:
4 AN 4 straight hose ends
4 AN 4 90° hose ends
8ft. of SS hose
3 1/8"npt to AN 4 male adapters (2 for the boost solenoid & 1 for turbo)
1 180° hose end
2 10mm x 1.0 to AN 4 male adapters (for the top & side of Tial wastegate)
1 AN 4 Tee
1 AN 4 weld bung (You don't need this if your going to use the turbo as the vacuum source)
If your turbo doesn't have the 1/8npt fitting on the compressor housing then you will need the AN 4 weld bung to weld to your ic piping. Please specify if you have aluminum or steel intercooler piping.
Comes with:
8ft. of SS hose
1 180° hose end
1 AN 4 Tee
These are the best pics that I have. Not the greatest but you get the idea. Depending on where you mount the boost solenoid, this will affect what bends you need. In the pictures above the boost source is taken from the intercooler endtank, because there wasn't a 1/8"npt port on the turbo.
Have you thought about selling a modified kit for the NLR controllers? It would surely add some extra fittings and line due to having to run 2 solenoids instead of one along with a pressure line for the controller itself.
Let me know everything you need and I'll give you a good deal.
gdrum
Feb 16, 2004 10:21 PM
