Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Bad Compressor??
Old Nov 20, 2008 | 02:47 PM
FamilyGuy's Avatar
Icon6 Bad Compressor??
After servicing the car and some maintenance issues resolved, the freon on my '03 4 Cyl Automatic EX Sedan, was emptied out.
Now I'm trying to re-charge the system, but the A/C compressor will not come on at all.
I'm not a certified mechanic, but know my way around cars. I have checked all fuses, connections, as far as I can tell. Does anyone have any other ideas as to what I may be missing??
I'd hate to go out and purchase a new compressor and have it be something simple. Any help will be greatly appreciated.
Thx,
Augie
Old Nov 20, 2008 | 03:47 PM
kikicamacho's Avatar
Default pressure switch
The low/high pressure switch needs to send a signal to the compressor to turn on. If you're trying to recharge using a can and low side adapter, make sure the valve is turned on to pressurize the system and allow the switch to turn the compressor on. It would be wise to have a shop evacuate, vaccum, and recharge the system for you. You will not get optimum performance until all the air and moisture is removed from the system and charged with the precise amount of refrigerant.
Old Nov 23, 2008 | 05:28 PM
slammed_s2k's Avatar
yupp ^^hes right
R_ACE1
Honda CR-V & Element
Sep 12, 2013 10:28 AM
faran
Jul 22, 2013 05:09 PM
97civic123
May 27, 2006 05:50 PM
Edwardo911
Aug 18, 2004 10:15 AM
foxfai
Aug 1, 2004 02:45 PM
