Engine harness color codes and plugs
Old Nov 20, 2008 | 02:06 PM
topherchris's Avatar
Default Engine harness color codes and plugs
Ok, so I'm out of area away from my car for a month...I have a new wiring harness I'm pulling apart and cleaning up to put on it when I get back, I have been searching for a little over an hour now and can't find the info that I need and since the car is on the other coast right now, I can't just pop my hood and look at it. I was pulling this wiring harness apart and found two wires that go to nothing, one is red with a white stripe and the other is green i believe also with a white stripe, also...I was wondering if anyone knows where I can find pictures of all of the plugs so I can label them before I get back, how I know which injector plug goes to which injector (I didn't get that plastic piece on it) and if anyone knows where i can buy all new pins and connectors at? All help is GREATLY appreciated, thanks.
Old Nov 20, 2008 | 02:16 PM
97Ej6mike's Avatar
Take pictures and post em, that would help out tremendously.
Old Nov 20, 2008 | 02:25 PM
94EG8's Avatar
Seagull Management
Thats most likely for the Intake Air Temperature sensor (IAT) It uses those wire colors.
A wiring diagram would help you a lot there. So far as I know, no one has picures up. As for the injectors IIRC they only reach the injector they are supposed to control.
I know they're made by tyco, you can probably get them through digikey.
Old Nov 23, 2008 | 10:55 AM
[QUOTE=94EG8;36462135]Thats most likely for the Intake Air Temperature sensor (IAT) It uses those wire colors.QUOTE]
what exactly is that sensor? im pretty sure it's not on the harness that's on the car now, is that something required to be there?
thanks, but if i was in a position where i could just go down and take pictures of it, i would not need to post this
Nate Boslet
Apr 17, 2017 05:16 AM
slams2k
Honda S2000
Jun 6, 2008 03:52 PM
89sparks
Jun 19, 2007 09:33 PM
DAGS-R
15
Apr 12, 2005 10:31 AM
importboi22
Feb 5, 2005 11:15 AM
