Engine harness color codes and plugs
Ok, so I'm out of area away from my car for a month...I have a new wiring harness I'm pulling apart and cleaning up to put on it when I get back, I have been searching for a little over an hour now and can't find the info that I need and since the car is on the other coast right now, I can't just pop my hood and look at it. I was pulling this wiring harness apart and found two wires that go to nothing, one is red with a white stripe and the other is green i believe also with a white stripe, also...I was wondering if anyone knows where I can find pictures of all of the plugs so I can label them before I get back, how I know which injector plug goes to which injector (I didn't get that plastic piece on it) and if anyone knows where i can buy all new pins and connectors at? All help is GREATLY appreciated, thanks.
Seagull Management
I know they're made by tyco, you can probably get them through digikey.
[QUOTE=94EG8;36462135]Thats most likely for the Intake Air Temperature sensor (IAT) It uses those wire colors.QUOTE]
what exactly is that sensor? im pretty sure it's not on the harness that's on the car now, is that something required to be there?
thanks, but if i was in a position where i could just go down and take pictures of it, i would not need to post this
DAGS-R
15
04-12-2005 10:31 AM
importboi22
02-05-2005 11:15 AM
