Injector wiring...
Old Nov 20, 2008 | 10:29 AM
Jayman_Gsr's Avatar
Default Injector wiring...
Here are the clips that I found online (ebay) to wire my 450cc DSM in my GSR. My question is just to make sure that I don't screw anything up.. The (+) on the Injector is the wire that needs to be to the common (yellow/black) on the teg? The reason I ask is cause the common on two of the injector clips seem to be flipped (check the pick injectors are laying with the pos. post outward or facing up)
Old Nov 20, 2008 | 10:57 AM
Jayman_Gsr's Avatar
Ok well I just looked at the stock injectors (On the car still) and the (+) is facing the left with the non-common wire, So should I just hookem up DSM(+) to STOCKGSR(+) and so on? So this would mean the resistor would go on the (-), which would be the common?
Old Nov 20, 2008 | 06:26 PM
Jayman_Gsr's Avatar
Bump at least tell me if figured it out if so
Old Nov 20, 2008 | 08:39 PM
PandaSJ's Avatar
bump
Old Nov 20, 2008 | 10:17 PM
95dc2teg's Avatar
polarity doesnt matter which means it doesnt matter which wire goes to which. just make sure you have wiring harness in the correct order. i.e. dont mix the wires that are supposed to go to the injector for cyl 1 with the wires that are supposed to go to cyl 3.
if that didnt make sense, i will try to explain in a little different way. the color of the wires doesnt matter. just solder the new clips in place of your old clips (dont worry about colors) and plug into the correct injectors.
Old Nov 21, 2008 | 05:18 AM
Jayman_Gsr's Avatar
ok just making sure I don't want to **** nothing up...Thanks
Arthas
Mar 3, 2010 05:08 PM
hyper em1
Jan 31, 2007 09:46 PM
RTW DC2R
Dec 16, 2006 04:16 PM
Mr. Vapor
May 7, 2005 01:03 AM
