Fuel Pump Question?
Old Jul 31, 2002 | 06:17 PM
b18b98's Avatar
Default Fuel Pump Question?
I have a 1990 Accord close to 170,000 miles and my fuel pump is about to take a sh** on me. I wanted to know how much a fuel pump goes for and should I go with OEM or aftermarket? Also, how hard is it to replace it in this car? Do I have to drop the gas tank or is it located right under the back seat panel like the newer Hondas? Or should I just take it to a mechanic? Thanks in Advanced.
Old Jul 31, 2002 | 07:31 PM
John's Avatar
New User
Default Re: Fuel Pump Question? (b18b98)
Yes, on Accords, you have to drop the fuel tank.
I recommend a Walbro fuel pump as a reliable, powerful fuel pump. Good prices at http://www.autoperformanceengineering.com.
Old Jul 31, 2002 | 07:33 PM
phatridinDus10's Avatar
Default Re: Fuel Pump Question? (DunReit)
Walbro intank 255 for me
Old Jul 31, 2002 | 09:26 PM
KTeller8's Avatar
Default Re: Fuel Pump Question? (phatridinDus10)
someone explain the intake and inline pump... i know with some piggy back units you must use one and the other for other applications
Old Aug 1, 2002 | 02:37 AM
niedejb's Avatar
Default Re: Fuel Pump Question? (KTeller8)
You only need the inline if you have an FMU. The FMU is a boost dependant fuel regulator that raises fuel pressure when boosting. Stock pumps cant keep up with the extra pressure so an inline is necessary.
I use a 4:1 fmu and a intank walbro 255l/h high pressure with no inline.
Old Aug 1, 2002 | 02:39 AM
niedejb's Avatar
Default Re: Fuel Pump Question? (niedejb)
Heres some pump pics. I briefly cover the installation of the intank on my webpage. Same as the accords.
Old Aug 1, 2002 | 05:42 AM
b18b98's Avatar
Thanks everyone. Now I'm gonna have to find the time to do all of this.
Old Aug 1, 2002 | 05:51 AM
John's Avatar
New User
Niedjb, you're the person I forgot who wrote a tech article on replacing the Accord fuel pump.
Old Aug 1, 2002 | 07:53 AM
b18b98's Avatar
niedejb - Can you give me the link to your artice on how to change the fuel pump. Your site does not have the link. Thanks in advanced.
Old Aug 1, 2002 | 02:14 PM
niedejb's Avatar
Its under installs. Better luck with your pump install than you had with navigating the site. Here's a shortcut just to make it easier.
http://home.insightbb.com/~niedejb/install.html
Old Aug 1, 2002 | 03:17 PM
Martaigne's Avatar
These are some good writeups. May I use these on Accordingly Done? You'll get full credit, of course.
Old Aug 1, 2002 | 04:00 PM
niedejb's Avatar
Default Re: Fuel Pump Question? (martaigne)
If you tell me what the heck it is/where it is. I'm assuming its a web site of some sort?
Old Aug 1, 2002 | 04:01 PM
Martaigne's Avatar
Yep, I'm making a performance site dedicated solely to Accords, you can look at the previw layout here: http://accordinglydone.myip.org/
Old Aug 2, 2002 | 05:32 AM
b18b98's Avatar
the reason why i couldn't find it was because our proxy here @ work was not working right. Whenever I went to your page, no images or links would show up. Once I got home, your page loaded up fine. Thanks for the link anyways.
cheeky ode
Aug 2, 2013 07:54 AM
PUREVIL
May 8, 2003 06:55 PM
wrXtian
Jan 20, 2003 07:49 AM
Teluan
Sep 4, 2001 08:56 PM
5gen-hybrid
Aug 5, 2001 10:17 AM
