no key in ignition (lights still come on)????
so i just put my dash back together on my 95 gsr and go to hook up the positive cable and the srs and brake light come on, also my maint light turns on.... with the key out of the ignition completely .i looked at all the grounds but everything seems fine. checked all the connectors and there all in there places .
can anyone give me some ideas of what might be doing this (something not plugged in or not grounded right??) thanks
check your stereo wires if they're cut then they're probably touching a metal bracket also check ALL your fuses maybe something shorted out while you were putting it back together if that doesn't help then pull it all back apart again and check it real good to make sure nothin had been cut or just simply not plugged in
found the problem as i was about to take the dash out i unhooked my moonroof switch then cluster....but before i went on i checked the cluster connectors and tried one last time and then it went away ....it was the moonroof connector when i first put everything back together i switch the connector around with the wrong relay.....
thanks to all who gave there input..
