OEM 94-97 Foglight related question.
Old Nov 19, 2008 | 11:42 AM
chevellion's Avatar
Default OEM 94-97 Foglight related question.
Just have a question on this piece on the USDM Switch Harness. Can you identify it and help by telling me where it goes? Thanks guys.
Old Nov 19, 2008 | 12:35 PM
super jdm yo's Avatar
thats the relay that'll go with your lights. i hear of a lot of people bypassing it. what it'll do is it'll only let your fogs come on when you lights are on. similar to the 90-93 fog lights. what you could do is tap into a acc wire so whenever your key is in the "on" position, you'll be able to use your fogs.
Old Nov 19, 2008 | 12:39 PM
BlueIntegraBoy's Avatar
It's the fog relay. Just bolt it up to any bolt under the dash. I used the same bolt as the main relay.
Old Nov 19, 2008 | 01:27 PM
steveharrmr23's Avatar
actually i just pulled out my harness and the have it mounted behind the driver side kick panel just be he the hood release lever on the top side of it there is a bolt the remove it and put the bolt threw the whole on the relay and the bolt threw the loop conector on that ground wire comeing from the relay
Old Nov 19, 2008 | 01:54 PM
chevellion's Avatar
I just wired it up and I guess I did something wrong. I press the button for the lights to come on. The indicator light lights up on the switch but the fogs do not light. I tried this both with the headlights on and off.
Old Nov 19, 2008 | 01:58 PM
they will not come one if you have your high beams on also did you plug that big red/wht wire into the clip the plugs into the back of the headlight control
Old Nov 19, 2008 | 02:05 PM
chevellion's Avatar
I did not try it with the high beams. Just the low lamps. I did plug this wire in. As well as the ground.
Old Nov 19, 2008 | 02:15 PM
where did you plug that thick red wire with the white stripe in at
Old Nov 19, 2008 | 02:21 PM
Old Nov 19, 2008 | 02:27 PM
R81_DC2's Avatar
check this out http://www.team-integra.net/sections...?ArticleID=913
hey sell me that harness
Old Nov 19, 2008 | 02:31 PM
chevellion's Avatar
I plugged that into one of the blank spots on the fuse box. I'm not sure where the headlight control switch is.
I plugged the wire in here.
Old Nov 19, 2008 | 06:06 PM
chevellion's Avatar
Lets get these fogs working
Old Nov 20, 2008 | 06:09 AM
on the harness that plugs into the fog lights on one end and plugs into that brown clip with the blue/red wire on the foglight side of that harness should be a ground wire where do you have that hooked up also where do you have that realy with the ground wire near it mounted at are the bulbs good or bad
Old Nov 20, 2008 | 06:24 AM
chevellion's Avatar
All of the grounds are wired. The ground wire under the hood is wired to the radiator support. The ground for the switch harness is against a bolt next to the hood release switch. Did I plug the red wire in the right area? I don't think one of those "blank" spots is the headlight control switch.
Old Nov 20, 2008 | 07:53 AM
one of them is that spot from the sound of it everything is hooked up correctly have you checked the fuse and the bulbs cause that is about all that is left
Old Nov 20, 2008 | 01:15 PM
chevellion's Avatar
The fuse is fine. I'll check the bulbs.
Old Nov 20, 2008 | 04:30 PM
chevellion's Avatar
Do I have to heat these in the oven order to replace the bulb? I've looked everywhere for a "DIY/How to" in order to open these up and replace the bulbs. When I move the lights around it sounds as if the bulbs inside are indeed broken. Can you guys help? Some of the screws are stripping as well.
Old Nov 20, 2008 | 07:34 PM
chevellion's Avatar
Well I figured out how to open up the light to check the bulbs. Easier than I thought. I'm falling in love with these things even before I've seen them light up haha. Well one of the bulbs was indeed broken. My question. Would this cause both of them to not light up?
Old Nov 21, 2008 | 09:12 AM
i am not sure it shouldn't the only other thing i can figure is that the relay is bad
Old Nov 21, 2008 | 09:15 AM
G Rabbitt's Avatar
I wouldn't think so.
Old Nov 21, 2008 | 10:17 AM
chevellion's Avatar
Possibly. I keep thinking I'm just wiring them wrong.
Old Nov 21, 2008 | 01:58 PM
jdmDAsix's Avatar
my **** stopped working. there's a short circuit on my left foglight(from what i've been told). i don't even know what to look for.
i got mine done by desmond like this. oem switch
another write up using jdm switch.
http://www.team-integra.net/forum/di...TopicID=251880
Old Nov 22, 2008 | 02:50 PM
qazaq's Avatar
see if this will help
palo $oldier
Jul 19, 2010 06:03 AM
pimpwagon
Jun 11, 2008 02:52 PM
Cashieboi
13
Jan 3, 2007 01:51 PM
SkyeC
Dec 15, 2004 12:37 PM
hondab18b2001
Jun 4, 2004 05:48 PM
