Top vacuum nipple on throttle body.
I am installing a full-race turbo kit on a JDM B18C swapped 1991 civic EF.
My question is this, There is a vacuum nipple on top of the throttle body, (originally hooked up to the charcoal canister) Can I use it as vacum source and hook the wastegate to this nipple?
Thanks guys
Thanks guys
I agree that the vac for the wastegate should be from a boost only source, meaning there is never vac present.
turbo compressor housings, hot side of the charge pipes are good places to tap a fitting in.
B16Civic93
Mar 18, 2005 04:33 PM
