wiring!?!?!?!?!
Old Jul 31, 2002 | 04:33 PM
4dohs4mohoes's Avatar
Default wiring!?!?!?!?!
im wiring up a new harness in my 95 ex and i ran into some probs. well first off when i try t start it all i get is a little click sound in the fuse box and i know its not the clutch signal switch. second everytime i hook up the battery there is a fuse in the engine ba fuse box that keep blowing. please help. if you have a swap guide on putting in a ex into anything i need that...or somthing. thanks
Old Jul 31, 2002 | 06:29 PM
DelSol808's Avatar
Default Re: wiring!?!?!?!?! (lilgreenhonda)
if fuses are popping you have a short circut somewhere so you should check all your wiring and make sure its correct...
Old Aug 1, 2002 | 12:50 AM
eg_nezay's Avatar
Default Re: wiring!?!?!?!?! (DelSol808)
lolv8s
Nov 2, 2016 04:44 PM
JDM*addiction
Mar 31, 2007 06:07 PM
