Frankenstien EH2 problem...
I just pulled my friends d15b+z6 head out of his crx, and put it into his hatch, and started tuning his ecu. I put a z6 basemap and messes with it a bit. Car started fine, a little while later tried starting it again and it wouldnt start. You could here the Walbro pump pumping gas when you turn the key, but thats all you hear besides the clicking of relays. Maybe an hour later stumped just messing with random crap, it magicly starts. A little later wouldnt start agin.
This keeps going on, we jumped the starter while I held the key and the car still wouldnt start, I redid all the engine grounds, battery is good, main relay is good. I have no clue what the hell ig going on. All the fuses are good as well. Im thinking it is possibly due to a relay that controls the starter signal, and the ignition. Is there a relay that controls the starter and the ignition? Main relay is good, replaced it, and the car is getting fuel...
Please help us, need to get the car running correctly so we can get the trubo put on...
Thanks Alot
Derek
Thanks Alot
Derek
AnonymousHatch
Jun 17, 2018 10:33 PM
ef9_pr0jekt
Oct 7, 2007 06:15 PM
wambus
Feb 12, 2004 03:09 PM
