any help appricated
on my security system there are a few wires i need help with i am working on a 94 dc4.
i have a door + and a door - which one get hooked to which wire in the cars door lock system?
there is also a #3 channel - wire what is it for?
there is also a trigger - wire what is that for?
Door triggers have nothing to do with your locks. Door trigger inputs get hooked into door triggers. Lock outputs get hooked to lock wires.
#3 channel is an aux channel, normally used for trunk pop. If your vehicle does not have power trunk release, then you would not use this wire.
A trigger wire? You'll have to be more specific. What does the manual say it does? It's apparently an input for the alarm, but to what it gets connected to is a mystery. It's probably a hoodpin or trunk trigger, but we'll wait until you crack open the manual and tell us a little more...
Make and model of alarm would help.
The "door + and a door -" are not for the cars door locks, they are for the door trigger, you will use the door -, [the door + is not needed].
The #3 channel is an EXT output, it would be used for something like trunk release or a power window module. also not needed in your car unless you want to add something like a power window module.
the "trigger - wire" can be used for a hood or trunk/hatch trigger.94
it is a avistart 4100 series but i am not using the remote start part of is so i am only using the freedom 500 module for the keyless entry and secruity system also i got it out of a car that was totaled in a junk yard
got it all figured out thx to all of yall that provided me with the information to make it possible it is so much fun for like five minutes i would arm it just to set it off haha i know not a good thing but could not help it
w1ck3dR
Audio / Security / Video
Feb 17, 2009 07:36 PM
saveacivic
21
Jan 24, 2007 07:18 PM
