Security System Help
Old Feb 14, 2004 | 09:12 AM
Cycoco's Avatar
Default Security System Help
Hi, I recently purchased a Crimestopper 2002 Car Alarm/Keyless Entry System for my 1996 Honda Accord Lx, but I am having trouble finding some of the wires. I was able to find the Ignition harness easily, and think I can tap into the wire behind the radio coming from the passenger door to get the door lock/unlock wires, but I cannot find the door trigger wires or the emergency flashers.
I figured I could just tap into the wire above the radio where the emergancy flasher button is but there are about a dozen wires going into the connector at that switch.
As for the door trigger, what purpose does it server to the alarm? Is it even nessessary to hook that up. Also, in my Accord there is a trigger for each door I guess, because the display can tell me exactly which door is open. Will this cause a problem?
ANY help or tips would be greatly appreciated!
Old Feb 14, 2004 | 09:51 AM
Ignitecivic's Avatar
Default Re: Security System Help (Cycoco)
the door trigger helps alot. i recommend u tap the door trigger. all u need to do is tap on of the positive or negative door trigger wire all 4 door will be active. without the door trigger some1 can just open ur door very soft and ur alarm wont go off. the door trigger helps it from sensing the alarm.
Old Feb 15, 2004 | 04:45 PM
STK B16's Avatar
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/white |- |gray conn. above fuse |
| POWER UNLOCK|orange |- |box in blue tape |
| PARKING LIGHTS +|red/black *1 | |blue plug fuse box |
| HEADLIGHTS|blue |- |blue plug left of column |
| DOOR TRIGGER|blk/wht |- |gray plug right of column |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|orange |- |gray plug right of column |
| TACHOMETER|blue | |at distributor |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|blu/red or grn/blu |- |steering column |
| WIPERS|blue |- |brown plug left of column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu |A |driver door harness |
| LR WINDOW UP/DN|grn/blu - grn |A |driver door harness |
| RR WINDOW UP/DN|yel/blu - yel |A |driver door harness |
Notes:
*1 Also a male blade terminal is available in the fusebox DKP.
Old Feb 15, 2004 | 08:12 PM
vooman's Avatar
Sounds like you need some professional help. If your asking questions like what the door trigger is, I would be very afraid for you. One advice, use a multi-meter to test your wires. Don't guess for wires it could lead to serious problems.
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
steveharrmr23
Nov 19, 2008 01:41 PM
saveacivic
21
Jan 24, 2007 07:18 PM
Maverik4k
Sep 22, 2004 09:56 PM
Odessa
19
Aug 3, 2004 06:37 PM
