1991 trailing arm !NEED HELP!
Old Nov 17, 2008 | 09:12 PM
Danny91hatch's Avatar
Default 1991 trailing arm !NEED HELP!
how much does it cost to fix or replace a bent trailing bar?
91 si hatch
Old Nov 17, 2008 | 09:18 PM
Deetz's Avatar
Crazy Honda Guy
buy a used one at the local junkyard for like $20
Old Nov 17, 2008 | 09:21 PM
awesome thanks.
are they easy to install?
Old Nov 17, 2008 | 10:09 PM
dacrxguy's Avatar
Originally Posted by Danny91hatch
awesome thanks.
well if u can take it off at the junkyard u are almost guaranteed that u can if in doubt buy a manual or dl one from the faq
Old Nov 18, 2008 | 05:27 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Its two bolts on the T-bar through the bushing to the chassis, the brake line, the bolts for the upper and lower rear control arms and a bolt of the front toe adjuster arm. I've got one off in under 20 minutes. Bring an air tank and you'll be done in almost ten.
Old Nov 18, 2008 | 09:12 AM
bake1782's Avatar
awesome thanks.
It's 5 bolts, and the brake lines and e-brake cables. Not difficult..IF THE BOLTS come out. I broke a couple bolts and the compensator arm for the toe adjustment usually just spins off inside the car. Pain in the ***...but if you have good luck and everything comes off easy....it's a 10 min job.
cehcivic15
14
Jun 18, 2012 12:50 PM
dth0ng69
Oct 24, 2009 09:55 PM
BoostinEJ1
36
Jun 10, 2004 10:54 AM
monotone485
Oct 21, 2003 02:00 PM
conesmasher
Mar 20, 2003 11:36 AM
