93 sol::windows,cluster,rad fan,directionals not working >which relay or fuse?
Old Nov 17, 2008 | 08:57 PM
Elwuudz's Avatar
Default 93 sol::windows,cluster,rad fan,directionals not working >which relay or fuse?
93 Del Sol B20vtec
I visually inspected every fuse I the car. None of the fuses seem to be broken even though one of them might be. I was just curious... the headlights and radio work. The Dome light and brake light works. And the car runs well, I just have no input from any of the sensors since the cluster is lit up but not getting a signal from the speed sensor. Even the fuel and temp don't come up. This all happened while driving after hitting a bump uncharacteristically hard.
I checked for a bad ground or short but found nothing.
Which fuse or relay should I replace to get the power windows, directionals and cluster input back?
Thanks in advance, I needs this info to drive the car safely while I seal the rings on the new b20vtec setup.
Old Nov 18, 2008 | 05:02 AM
Elwuudz's Avatar
BUMP
m.glisson003
Jan 25, 2013 08:22 AM
agustintorre
Sep 14, 2012 06:55 PM
k20em2
May 17, 2010 04:11 AM
Dragger817
Feb 13, 2007 05:07 PM
5thGenFanatic
Nov 6, 2006 10:32 AM
