how do i fix this.. i need brakes!!!!
Old Nov 16, 2008 | 07:48 PM
callmetree19's Avatar
Default how do i fix this.. i need brakes!!!!
i just replaced my mast brake cylinder and break booster after breaking it. when i hooked everything up and looked at i saw that it was dripping brake fluid from where it tooks up to the master cylinder, so i pressed on the brakes and it was pouring out of of them. i went back in tightened everything is it was still doing it.. i have a little video of it. but has this ever happened to anyone and how to you fix it? :thinking:
how the hell do you fix this?
Old Nov 16, 2008 | 08:01 PM
EvilPhu's Avatar
Default Re: how do i fix this.. i need brakes!!!! (callmetree19)
Look like it's not tight (sticking out quite far), or you have strip the thread on it. GL
Old Nov 16, 2008 | 08:09 PM
damn i need my car for tomorrow too. i think i'm going to try and get some more.. and see what happeneds. thanks..
Old Nov 16, 2008 | 08:11 PM
Mrmatt3465's Avatar
Default Re: (callmetree19)
Not sure if this applies but did you use teflon tape on the threads? Remember to wrap the tape the right way too!
Old Nov 16, 2008 | 08:19 PM
94EG8's Avatar
Seagull Management
Default Re: (Mrmatt3465)
Do not use teflon tape on brake lines, ever. Those fittings will never seal if you do.
Old Nov 16, 2008 | 08:24 PM
i almost did.. then i was about to use Jb weld b/c i was sick of this ****
gsrhatch2356's Avatar
Default Re: (94EG8)
you dont have it tighten down all the way
Old Nov 16, 2008 | 08:29 PM
that as far as it will go. i'm getting more tomorrow and i will take them old ones off and the master brake cylinder and put them all as one.. thats why its going that?
pedroa06
Sep 3, 2009 06:23 PM
90 integraian
Suspension & Brakes
Sep 25, 2008 05:11 AM
namax
Jul 16, 2007 05:43 PM
94lspower
May 19, 2007 08:42 PM
crxtreme27
May 19, 2003 12:04 AM
