Will 06-08 si seats fit in my 97 dx hatchback?
Old Nov 16, 2008 | 02:29 PM
iiPancho's Avatar
Default Will 06-08 si seats fit in my 97 dx hatchback?
I was looking for new seats and I was wondering if the 06-08 si seats would just bolt right in or if i would have to get new stuff to put them in, or do they fit at all?
Thanks
Old Nov 16, 2008 | 03:48 PM
iiPancho's Avatar
Default Re: Will 06-08 si seats fit in my 97 dx hatchback? (iiPancho)
help?
Old Nov 16, 2008 | 04:27 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
I think I recall reading that they might be similar to RSX seats, which require modification to fit. The photos I've seen of RSX seats do not show them fully bolted in.
I'd post a link if I knew of one off hand. I know there are threads about it though.
Old Nov 16, 2008 | 05:59 PM
Ruben19's Avatar
you have to modify your seats rails
Old Nov 16, 2008 | 06:55 PM
iiPancho's Avatar
Default Re: (Ruben19)
What kind of modification?
Old Nov 18, 2008 | 05:40 AM
tercel95's Avatar
they either require ghetto rigging or serious modification. They will sit too high. In my opinion they are just too large for the car. I would go with s2k seats.
Old Nov 18, 2008 | 08:10 AM
big-cat's Avatar
ehhhh. depends on your size if you want the s2000 seats, i put them in my car and i am 6' 210 and cant fit in them at all, I want to try out the rsx seats to see if my wide shoulders will work with them.
Old Nov 18, 2008 | 09:19 AM
tercel95's Avatar
Yeah I guess I didn't think about you huge guys. I'm 5'9" 145lbs and I dig the s2000 seats. However I also really like the EP3 Si seats but I think they are just too big for an eg or ek.
Old Nov 18, 2008 | 10:16 AM
6SPD_EK's Avatar
I have done it in my ek - I even had a thread I made about it but since honda-tech changed over i can't find it WTF!!!!!
I cut the mounting brackets of the ek seats & welded up custom made brackets to mount to fg2 seats
fyi - the seats sat slightly lower than stock dx seats...
Old Nov 18, 2008 | 01:03 PM
iiPancho's Avatar
Was it hard to do? can you give me anymore information on it?
thanks
Old Nov 19, 2008 | 05:34 PM
iiPancho's Avatar
Old Nov 19, 2008 | 05:41 PM
crazyz250's Avatar
yes they will, my friend put a 07 civic si seats in his 95 civic 4-door (3 of the 4 holes lined up, he just cut/welded a new footer on that 1 hole). the 92-95 civic and 96-00 civic have the same mounting points so you should be good
Old Nov 19, 2008 | 06:44 PM
6SPD_EK's Avatar
although what you said can be done, you are wrong about eg & ek chassis having the same mounting points. they are slightly difference - proof is in that eg/dc use different bracket mounts than ek, for the same recaro seat
here what I did to mount mine
a.) cut off the mounting brackets from the bottom oem eg/ek/dc seat brackets - they are welded on so cut the welds. brackets are blue in diagram
b.) bolt the brackets down & weld 3/16 to 1/4" ( by 1") steel bar (in black in diagram) to the brackets. 2 or 4 bars per seat (2 side to side & optional 2 front to rear). the weld points are in red
c.) remove the brackets welded in a & b & weld them to the bottom of the rails of the fg2 2006+ si seats (welds shown in green) note one of the seats had a double decker bracket but when you remove the fg2 si seat brackets the seats with the rails sit at the same height
here is the only pic I have of a corner of the bracket welded up
note the spot weld you see was just to tack the bar - it was completely welded on the underside (out of view in pic)
Old Nov 19, 2008 | 08:07 PM
SeanZ0r's Avatar
Looks good 6spdek, I Have one ep3 seat in my Ek, I love how it feels. On the Stock EP3 seat, the little "feet" that are riveted onto the seat rails need to be moved, and on the seat rails there is already holes drilled from honda, So you will need to grind out the old rivits, and move them into the other hole, but its the right rear foot(on drivers side) that has to be extended about an 1" so it can be bolted down.
Old Nov 20, 2017 | 08:13 AM
AstroNawt's Avatar
I know im a little late to the party ... but if anyone has a more in depth video or instructions on how to swap out the 6th gen seats with 8th gen seats I would really appreciate the help.
thanks a bunch guys
AstroNawt
Old Nov 20, 2017 | 08:34 AM
tony_2018's Avatar
Fish Twig
There is none, you need to cut the brackets off, or drill out the spot welds, do the same for the fg/fa seats, get a metal bar as you see i nthe image above and weld them all together.
jdowen2
Honda Civic (2001 - 2005)
22
Dec 29, 2008 06:49 PM
josedc5s
Jul 5, 2007 01:35 AM
007FIT
Honda Fit
Jul 14, 2006 03:44 PM
ZC_powered_4dr.
14
Aug 14, 2005 01:25 PM
mikey1987
Dec 2, 2004 01:33 PM
