ABS light on help
Well my stupid ABS light has come on today in my 94 EX i was just wondering how i can fix it (other than remove it) it has been sittin for 2 years could it be air in the system as i have not bled it yet any ideas?
check your wires around your brakes. . they are left in the open. . mine had been hit by a stone and cut. . put it back together reset the battery and its good now. . look around maybe you'll find a wire issue. . you can also check your ABS code the same way you check your engine light code. . dont ask me how to do that. . thats what search is for
well just like engine diagnostics, my crystal ball is hazy but if you got some codes off it then it would help us lead you in the right direction. its my understanding that you just jump the same wires that you would when you are trying to get engine codes. so when you do let me know the code #'s and I will get my crystal ball back out, it could be a little clearer at that time
well the damn light is intermittent it didnt come back on today so it probably just a messed up wire on the front. How hard is it to just take out all the abs crap.
just take the ABS light bulb off your dash.
This is how you fing the code.
The code connector is above your ECU.
Is a 2 wire cable with a brown head.
Get a paper clip/ jump it.
Turn your ignition on
start counting the ABS light blinks
Slow blinks means 10
fast blinks meas 1.
Go online and find the ABS codes
fast blinks meas 1.
i don't have an abs light on but the abs comes on unnecessarily everytime i stop after i put in integra spindles.
i think the civic abs sensors are shorter than the integra sensors.
anyone can confirm this?
