reverse lights wont work
Old Nov 16, 2008 | 08:31 AM
twistedek's Avatar
Default reverse lights wont work
just notice my reverse lights wasn't going on when i put it into reverse. i tryed to check it by using a wire at the harness to jump it but didnt work and all the fuses are good. so any ideas or help u can offer would be great.
Old Nov 16, 2008 | 09:00 AM
6footmidget's Avatar
Default Re: reverse lights wont work (twistedek)
maybe the bulb burned out?
Old Nov 16, 2008 | 09:23 AM
twistedek's Avatar
Default Re: reverse lights wont work (6footmidget)
ya i checked the bulbs and they looked fine but im going to change them out anyway just maybe i missed something and hopefully that works.
Old Nov 16, 2008 | 09:48 AM
reaction360's Avatar
has it worked before? did u check your wires on the tranny?
Old Nov 16, 2008 | 03:19 PM
twistedek's Avatar
Default Re: reverse lights wont work (reaction360)
yes it worked before and only just recently noticed that it wasn't. the wires are all where they need to be on the tranny. but is there anywhere else i can possible check or things that i can do to trouble shoot this problem.
Old Nov 16, 2008 | 05:21 PM
The_Honda_Guy's Avatar
If I were you I'd first check that the fuse isn't burnt out. After that you should check to make sure the reverse switch on the transmission is functioning properly as long as the bulbs aren't burnt out.
Old Nov 16, 2008 | 05:25 PM
hard_boiled_EG's Avatar
Default Re: (The_Honda_Guy)
i think it's the reverse switch if everything else is fine...
Old Nov 18, 2008 | 07:34 PM
JdmOdz's Avatar
id think its the wires on the tranny.. but get a wire tested and check to see if its getting power to the bulbs.
90DB1TegSedan
May 20, 2012 08:33 PM
prelude uk
Dec 9, 2005 03:26 PM
disposable
Sep 5, 2005 10:02 AM
Chronicsinners
11
Mar 3, 2005 08:25 AM
808style
Apr 16, 2004 02:27 AM
