Almost finished with my D15Z1 engine swap, but now have CEL and it's not running right.
Old Nov 15, 2008 | 06:23 PM
therotaryrocket's Avatar
Default Almost finished with my D15Z1 engine swap, but now have CEL and it's not running right.
I still need to install my radiator and wire up the map and oxygen sensors. I figured it would run without those two sensors, at least better than it does. Right now, it started pretty easily but throttle application has no effect on it's running, although I was scared of hurting something or backfiring so I didn't press the gas open too much. It just jumped to about 2000 rpms and pulsated up and down 200 rpm.
I know, I'm close, i just need to get an egr control box, and connect that, the map sensor, and the O2 sensor.
However, many of the pinouts I've found are not consistent, I don't know exactly what diagram to go by. I downloaded the Helm's from the FAQ for the 92-95 civic, and so far I can't find what I'm looking for.
btw, I used the TPS from an 88-91 Prelude MPFI throttle body. I don't have it adjusted exactly yet, but I imagine that my problems are something else. The check engine light was illuminated while running, and I tried to ground D7 so that the CEL would blink, but nothing happened? Maybe I'll try again tomorrow and try and sand of the paint somewhere so I can get a really good ground.
kreatekustomz
Mar 1, 2010 02:12 PM
89CivicHb1
Oct 30, 2008 12:38 PM
dtarvin
Sep 3, 2008 03:23 PM
SIsohcvtec
Sep 25, 2004 10:00 AM
ImportRacing
Nov 3, 2002 09:04 PM
