90 integra wont start..got fuel,and spark ? help
Old Nov 15, 2008 | 04:51 PM
LHC_90_acura's Avatar
Default 90 integra wont start..got fuel,and spark ? help
my 90 integra wont start i have checked the timeing and i have spark and fuel
Old Nov 15, 2008 | 05:59 PM
90tegblueonblack's Avatar
Default Re: 90 integra wont start..got fuel,and spark ? help (LHC_90_acura)
need to know more than that
its turning over?
tried giving it gas yet? does it even cause a slight change, tried spraying gas in it to make sure its not your fuel pump?
anything
at all
details?
Old Nov 15, 2008 | 06:35 PM
Default Re: 90 integra wont start..got fuel,and spark ? help (90tegblueonblack)
theres gas in it and we tryed spraying gas in it its pumps the gas up to the fuel rail but im not sure if the the fuel rail will work i have a b20 block with a b18 head and one of my buddys just put the stock fuel rail in it will that little rail work on that engine. or is there a relay for the electroinic injectors ????
Old Nov 17, 2008 | 10:13 PM
jdm_xsi206's Avatar
my homie had the same porblem. try to check your ecu. after he changed the ecu his car ran... but good luck wit it
Old Nov 18, 2008 | 05:21 AM
integraturbo's Avatar
kick ur main relay
Old Nov 18, 2008 | 05:38 AM
ziggy7's Avatar
Fuel is getting to the rail but are the injectors firing?
Old Nov 18, 2008 | 08:44 AM
stocker2shocker91's Avatar
I requested a short story for a title.
ya check them injectors.. if you have a stethoscope you could listen to see if there ticking
Old Nov 18, 2008 | 12:48 PM
ziggy7's Avatar
another way to test and injector without the car even having to be on is to take a 9v battery with two piece of wire and just touch the wire to the leads on the injector and listed for the click, no click=bad injector!
dreadhead89
Dec 26, 2008 09:14 PM
project92ex
Oct 24, 2008 06:15 PM
bengal
Aug 9, 2006 08:50 AM
alfee
Apr 14, 2005 12:40 PM
turbologist
Oct 7, 2003 06:00 PM
