Remote starter and Keyless Entry install, advice needed.
Old Nov 15, 2008 | 12:12 PM
vtecn8ive's Avatar
Default Remote starter and Keyless Entry install, advice needed.
I just received my Ultra Start G-11-xr remote starter/keyless entry. Its for my winter car so I do not need an alarm on it, just the essentials.
The car is a 90 Civic 4rd Sedan with OEM power locks.
This is my first time installing it and I have about 2/3 of the wires figured out. However, a couple I'm unsure of are as follows:
Diesel Wait to Start input <U>(i'm assuming since its gasoline?)</U>
Tach Detection input (a/c) <U>(is this needed? i have the wire I would use but unsure if need it)</U>
Re-arm output (-) 250mA
Dis-arm output (-) 250mA
Grouwnd While Running Output (-)
I also, received the instuctions for how to install it into my car (kind of or I wouldn't be asking this stuff)
What do I hook these up to:
dome light,
ignition 2,
ignition 3,
neutral safety switch,
reverse light,
key sense,
I have ideas of what I think needs to be done but not 100%. I haven't had time to research this (plan to tonight after work) Just wanted to get this up asap so people could help me out.
Thanks,
Shane
Old Nov 15, 2008 | 12:20 PM
zrickety's Avatar
Default Re: Remote starter and Keyless Entry install, advice needed. (vtecn8ive)
the system should have a website or sheet that tells you those wires...i used to have one by bulldog security and this may help:
http://www.bulldogsecurity.com...1.htm
search around some more and you should be good
Old Nov 15, 2008 | 12:52 PM
D16SiHatch's Avatar
Default Re: Remote starter and Keyless Entry install, advice needed. (zrickety)
This should help you figure out what some of those wires are
http://www.directeddealers.com...t.pdf
-the diesel wait to start (don't need obviously, you don't have a diesel and don't need to wait for glow plugs to heat up)
-tach detection input (is needed, otherwise once you remote-start it wont have any idea if the car is running or not)
-the re-arm and dis-arm output (for if you have a factory alarm that you want the aftermarket alarm to now control)
ground while running(i think is just to activate a relay and turn something auxilliary on while its in remote start mode)
kreggor
Audio / Security / Video
Dec 2, 2016 06:20 AM
1BADEGDC2
14
Dec 10, 2008 07:06 AM
slowjett
Dec 26, 2006 08:55 PM
nyo91
Mar 19, 2004 05:25 PM
menelaus22
Dec 3, 2002 01:10 PM
