Distributor control injectors?
Old Nov 14, 2008 | 07:29 PM
EFvtec Yo!'s Avatar
Default Distributor control injectors?
Question for you guys... Does anyone know if the distributor sends any kinda signal for the injectors to pulse. I am stumped on my MPFI swap. still gettin no power at all to the injectors. Thanks for ANY help!
Old Nov 14, 2008 | 08:10 PM
dohccrxsi's Avatar
check firing order.
Old Nov 14, 2008 | 08:14 PM
EFvtec Yo!'s Avatar
firing order is correct. I am gettin decent spark and I am gettin gas all the way to the fuel rail. No power at all to the inectors (tested that with a noid light) Replaced the injectors, main relay and ECU. Thanks for the response though. Any help is appreciated!
Old Nov 14, 2008 | 08:20 PM
D16SiHatch's Avatar
Default Re: Distributor control injectors? (EFvtec Yo!)
do you have the resistor box hooked up properly?
Old Nov 15, 2008 | 05:16 AM
EFvtec Yo!'s Avatar
Default Re: Distributor control injectors? (D16SiHatch)
Yessir double checked that too. Is it possible that the resistor box can be at fault? I have never heard of one of them being bad.
Old Nov 15, 2008 | 07:19 PM
EFvtec Yo!'s Avatar
bump
Old Nov 15, 2008 | 08:53 PM
sinepome's Avatar
Default Re: (EFvtec Yo!)
i dont know if its bad but i have 2 for sale and i live in GA also you can try it out.
Old Nov 16, 2008 | 06:47 PM
EFvtec Yo!'s Avatar
Default Re: (sinepome)
Thanks man, but i tried a buddies working resistor box today and still the same problem. I am about to give up. LOL I have no clue why the injector plugs are getting no power.
Old Nov 16, 2008 | 08:03 PM
01-0041's Avatar
What is the ECU telling you?
Number of flashes???
Proper grounds???
Old Nov 16, 2008 | 08:07 PM
harumph's Avatar
Default Re: (01-0041)
I am with this guy. I think you need to look at the ECU. Make sure you have the correct one. I believe the ECU tells the injectors when to fire.
Old Nov 17, 2008 | 07:56 AM
EFvtec Yo!'s Avatar
I am using a PR4(obdO LS) ecu and am getting no codes at all. I had a PR3 sitting around so i popped that in there to see if that would do anything. still nothing. All grounds are hooked up (t-stat housing, valve cover, tranny ground...)
Old Nov 17, 2008 | 08:17 PM
90sedan's Avatar
Sounds like incorrect distributor wiring to me. The ecu uses the TDC sensor in the distributor to determine when to fire the injectors, with it wired wrong, they won't fire at all. And since you said that you are getting "decent" spark and not good/great I'm definitely willing to bet you need to double check your distributor wiring.
Old Nov 18, 2008 | 01:07 AM
EFvtec Yo!'s Avatar
I have checked my distributor wiring and all looks fine. I did purchase an obd2a-obd0 distributor jumper harness on here and I am starting to think that maybe that jumper harness is my problem. I think i am gonna locate me an obd0 dizzy and get rid of that jumper harness and obd2 dizzy.
Old Nov 18, 2008 | 08:09 AM
D16SiHatch's Avatar
even though its converted with the dizzy harness you can't use an obd0 ecu with an obd2 dizzy. you need the dizzy to match the ecu. so get an obd0 diz and you should be straight.
Old Nov 18, 2008 | 07:14 PM
EFvtec Yo!'s Avatar
Really? so even though i have a jumper harness to jump that obd2 dizzy down to an obd0 dizzy it wont work with my obd0 ecu? If this is true you might have solved my problem! I guess i need to source an obd0 dizzy. Anyone else have any input on the above post before i purchase an obd0 dizzy?
Old Nov 19, 2008 | 01:24 AM
Pandor's Avatar
The above is correct.
obd0 ecu needs obd0 distributor.
>=obd1 ecu needs >=obd1 distributor
the jumper harness is only to convert your engine wire harness. ecu and distri still need to be matched. Else it won't work.
Old Nov 19, 2008 | 03:17 AM
rbwdriven's Avatar
I had same issue with my b16 trying to fire it up sounded like not getting gas when it was firing. also looked like it had a spark.
I had a buddy fire it while I held the spark plug. Could see the spark. I check the gas, had gas.
I said for giggles change out the ignitor module in the dizzy.
Turned ignition on boom ran like a charm.
Whystherumgone?
Mar 15, 2017 05:11 AM
B16Civic93
Jan 20, 2014 04:30 PM
EKiddd
Oct 4, 2013 07:32 PM
allisonmo2
Oct 9, 2008 04:48 PM
n2oef
Jan 21, 2005 12:54 AM
