tune up (i did a search)
Old Jul 31, 2002 | 10:01 AM
JMX's Avatar
JMX
Default tune up (i did a search)
what are the average and not so average part i should replace for my 100,000 mile tune up
cap-rotor
fuel filter
pcv valve
maybe wires
what elese????
Old Jul 31, 2002 | 01:17 PM
EE_Chris's Avatar
Default Re: tune up (jmx2323)
Not knowing what you have already done vs. when you've done it, I'll just list some stuff off:
Cap, Rotor, Plugs & Wires
PCV
Adjust your valves
Timing Belt & Tensioner
Upper & Lower radiator hoses + coolant flush + water pump
Thermostat
Belts
Tranny Fluid
Flush your brakes and clutch
Air Filter
Fuel Filter
Then again, if you had a Helms, you could easily look at there "Maintenance Section" and deduce for yourself.
babietuan323
Apr 3, 2006 01:45 PM
skiptomylou
Mar 22, 2006 04:46 PM
jeremy.
Feb 8, 2005 10:42 AM
EF4lyfe
Sep 27, 2004 03:59 PM
BoostFrenzy.com
Apr 8, 2004 08:09 AM
