STILL GOT IDLE SURGE ISSUES......I NEED TIPS PLEASE!!
Old Nov 14, 2008 | 09:43 AM
91CR-XSiR's Avatar
Default STILL GOT IDLE SURGE ISSUES......I NEED TIPS PLEASE!!
I GOTTA B16A W/JDM CTR PISTONS, BUDDY CLUB CAMS, JUST INSTALLED BLOX INTAKE MANIFOLD W/ A FUEL RAIL FPR AND A FUEL FILTER ALL BY BDL. NOW IV'E HAD IDLING ISSUES SINCE THA SWAP. IVE TRIED A NEW IACV, I HAVE NO FIV CUZ THA BLOX INTAKE MAN. NO VACUUM LEAKS. NO AIR IN COOLANT SYSTEM. TPS IS SET AT .5 CLOSED THROTTLE. THA HEAD IS ALSO HAD 3 ANGLE VALVE JOB , AND DUAL BLOX SPRINGS FROM IMPORT AUTO PROS BY DAVID (AKA TIMEBOMB). I DESPRATELY NEED SOME GOOD POINTERS HERE. THA IDLE FLUCTUATES ABOUT EVERY SECOND AND HALF ABOUT 600RPMS, WHEN WARM AND WHEN COLD. PROBLEM IS KINDA INTERMITTENT, I SAY THAT WITH IDLE FLUCTUATING MORE OFTEN THEN NOT.....PLEASE HELP A HOMIE OUT!!!! THANX!!!
----MATT-----91CR-X SiR
Old Nov 14, 2008 | 02:47 PM
JNocon's Avatar
I experience this kind of problem b4 w/my friend's EG. It flutuates...it seems he has a WILD CAM in his engine, but, he doesn't! I tried everything to make the idle stable, so, I looked at all his wiring(no shorts/open), sensors...then what I saw behind his I.M., his small coolant hose was pinched connected to the AIV and TB.
Old Nov 15, 2008 | 07:49 AM
91CR-XSiR's Avatar
Default Re: (JNocon)
thanx man....checked and had coolant hoses replaced, and i do got a buddy clud III cams n str gears....n e one else cuz i really gotta fix this, can it be ecu related? i got obd0 to obd1 conversion.....n she seems to be running rich!!
Old Nov 15, 2008 | 07:57 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: STILL GOT IDLE SURGE ISSUES......I NEED TIPS PLEASE!! (91CR-XSiR)
i kno u said that u had no vac leaks. .but r ur vac lines routed rite??
Old Nov 15, 2008 | 10:29 AM
91CR-XSiR's Avatar
Default Re: STILL GOT IDLE SURGE ISSUES......I NEED TIPS PLEASE!! (Egezzy)
IM PRETTY SURE, I GOT THA FPR TO THE FRONT VAC LINE, MAP IS ON THROTTLE BODY AND EGR IS ON BACK OF MAN.......DO U GOTTA SHCEMATIC I CAN LOOK AT ???? ILL DOUBLE CHECK IT THANX EGEZZY!!
Old Nov 15, 2008 | 11:03 AM
namewasdallas's Avatar
try taking off the throttle body and spraying throttle bodie cleaner in it, I just had a low idle and i just sprayed it out not much black came out but it idles like new now and i sprayed some on the throttle cable were it meets the throttle body.
Old Nov 15, 2008 | 03:12 PM
JNocon's Avatar
Default Re: (91CR-XSiR)
Hey, on your Buddy Club cams, did you purchased it new and somewhere on the paper, stating that when you installed this cam, your engine will have a loopy idle...or was it already there from the getgo? OBTW, is the engine tuned already?
Old Nov 15, 2008 | 05:49 PM
91CR-XSiR's Avatar
tha motor alway idled that way since i installed it, ive also set tha tps to .5 closed throttle and everytime i bring tha idle down to bout 1100 and lower with tha ilde screw, it starts to fluctuate.......i have went over with my technicians, i work at a midas shop in whittier, and we are starting to belive it may be ecu related or and o2 sensor and or spark plugs that are visibly black and a bit damp (not oil) . ...............theory; incomplete combustion=rich reading, and or o2 burned (used one), (i have another used one to use), causing ecu to get "loopy"????? im soooooooo ppppp ooooooed!!!
Old Nov 18, 2008 | 07:13 PM
JNocon's Avatar
Hey, just a thought, you have an xtra ecu? Try switching that, if doesn't work, it might be your TB w/ the idle screw(I know you cleaned it and everything). Coz, last year I had almost the same problem, I did every thing I can, so, I started eliminating the problem 1 @ a time. I ended up w/ 2 parts as my problem(ecu and TB), switched it, and my idle runs fine now!
Old Nov 19, 2008 | 05:11 AM
popwars123's Avatar
do you have a lightweight flywheel and crank pulley?
for me..i had a fidanza 7lb and a ctr puley and it wouldnt idle below 1100 because it didnt have enough inertia to keep turning it over that low of a speed..it wanted just turn up really fast
Old Jan 6, 2009 | 01:40 AM
gofastcrx's Avatar
it needs a dyno tune matt.
Old Jan 6, 2009 | 07:16 PM
mouab18c1's Avatar
check your ignition timing again and your TB IDLE SCREW
Old Nov 8, 2009 | 01:35 PM
91CR-XSiR's Avatar
Icon3 Re: STILL GOT IDLE SURGE ISSUES......I NEED TIPS PLEASE!!
I THINK IM BE GETTIN THAT TUNE SOON HOMIE, SHEZ BACK IN ACTION BUT I GOT THAT IDLE SURGE STILL. I REALLY NEED THIS FIXED, ITS THE EFFING ROCKS IN MY SHOEZ!!! SO I CHANGED THE PLUGS OUT CUZ THEY WERE STILL THE NGK V-POWER SO I GOT THE NGK IRIDIUM IX. THEY SEEM TO BURN A LOT BETTER BUT ITS STILL RICH AS BILL GATES. TIPS??????????? N E 1 PLEASE!!
Old Nov 8, 2009 | 07:48 PM
fourthgenhatchB17's Avatar
Thats as good as the tips are going to get. End of thread.
1991civicb16
Jul 16, 2011 12:38 AM
SD_BB2
Sep 16, 2010 09:53 AM
byronl
Dec 20, 2006 05:29 AM
civc_tt
Jul 30, 2006 11:00 AM
crexer
20
Mar 13, 2005 01:35 PM
