PLEASE HELP! NEED TO DECIDE SOON!!
hey, my passenger window in my em1 stopped going up or down. i think its the switch so i was told that i should replace the driver side switch and not the passenger side. i just need to clarify this before i buy the switch its like $50! thanks
does your drivers side window roll down/up your window? does your passenger do it either? it is rare that both of your switches dont work...if neither one works then check the motor/regulator.
take the door panel off.
Disconnect the window motor harness.
Get 2 jumper wire, one positive and one negative.
get a battery or jumper box.
If the motor moves, then you know is good.
kptrk06
Honda Civic (2001 - 2005)
Jun 29, 2014 09:26 PM
Psychoteen101
Dec 16, 2013 10:31 AM
Edgemingsr
Jun 2, 2004 10:08 PM
