fuel injector Question ?
Old Nov 13, 2008 | 06:27 PM
Joeski99Si's Avatar
Default fuel injector Question ?
just wondering if somebody can tell me if a 99 civic si( B16) needs high impedence or low impedence fuel injectors ? ? ?
Old Nov 13, 2008 | 06:43 PM
mnskateboarder's Avatar
high impedance/saturated and you will not need resistors. yo need resistors if your using low impedance, so depends what size injector you need.
Old Nov 13, 2008 | 06:44 PM
uniseriate's Avatar
Default Re: fuel injector Question ? (Joeski99Si)
High impedance (saturated). This site has a nice table.
Old Nov 14, 2008 | 02:52 AM
Joeski99Si's Avatar
Default Re: fuel injector Question ? (uniseriate)
thanks. . so if i buy precision 525cc (high impedence) injectors will they plug right in or will i need the injector replacement clips. my motor is OBD2 but i am converted to a obd1 ecu !
Old Nov 14, 2008 | 06:38 AM
hotrod99's Avatar
you still need the injector clips
Old Nov 14, 2008 | 08:44 AM
Schister66's Avatar
Man U FTW
Before answering your question, i want to ask you a question. Why are you upgrading injectors? There is more to an injector choice than whether or not you have to wire resistors...your fuel demands are far more important.
1. Why are you upgrading?
2. What is your power goal?
Old Nov 14, 2008 | 09:54 AM
Joeski99Si's Avatar
Default Re: (Schister66)
turbo kit . . 7psi stock internals
Old Nov 14, 2008 | 10:22 AM
Joeski99Si's Avatar
Default Re: (Joeski99Si)
any suggestions ?
00mustanggt
Mar 17, 2015 09:39 AM
Fuel Injector Clinic
Sep 29, 2014 06:14 AM
enhancedCL9
Jan 6, 2004 10:27 PM
