help on code po420
Old Nov 13, 2008 | 12:30 PM
Bozo_JDM's Avatar
Default help on code po420
i was driving normal and my check engine light came on with a po420 any one have this problem
02 acura RSX
Old Nov 13, 2008 | 01:09 PM
forced97's Avatar
Default Re: help on code po420 (Bozo_JDM)
cat code clear and see if comes back if it does time for a new cat converter
Old Nov 13, 2008 | 04:46 PM
johnclaunch's Avatar
Default Re: help on code po420 (forced97)
Okay, so much for the generalized, no help answers.
In truth a P0420 is Catalyst System Efficiency Below Threshold (Bank 1). Your front side O2 sensor is having issues. Have you modified the car at all? If not, this code can sometimes come on for a number of reasons most of which are flukes. Reset the code, or just drive for a few days and see if it goes out on its own. If there is no real problem, the ECU will realize this and reset the code on its own. Check to make sure the front side O2 sensor is secured into the catalytic converter and that the wires for said sensor were not disconnected. There are many possible results but the last of which and the most unlikely is the need of a new converter.
Old Nov 16, 2008 | 02:55 PM
Bozo_JDM's Avatar
i erased it and hasnt come back thanks
Old Nov 16, 2008 | 06:38 PM
burnout8488's Avatar
How many miles?
Old Nov 18, 2008 | 02:25 PM
newport45's Avatar
that code means roll one up
Old Nov 20, 2008 | 08:21 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
So much for incorrect info..
The front sensor is the A/F sensor not an o2 sensor and has nothing to do with the cat. The PCM uses this sensor to determine proper fueling in order to maintain stoich.The rear sensor is the o2 sensor and its sole purpose it to monitor the cat. This is the sensor that will set a code when the cat is no longer effecient or in some cases it will set a false code because the sensor itself is faulty...
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
xprohx
Jul 29, 2008 12:03 PM
adobospoon
Oct 30, 2005 01:11 AM
danteisme
Mar 16, 2005 07:01 AM
btrim23
Mar 14, 2005 08:01 AM
