Will adding a catalytic converter change the A/F ratio?
The car has been tuned on crome with I/H/3" R&D exhaust (no cat). It's a stock motor. Recently, I welded on a Vibrant metallic race cat along with 2 resonators to shut it up. Will this change my A/F ratio - need to be re-tuned?
Anything that changes air flow through the motor will change your A/F ratio.
The cat is a restriction, probably not much but some...if anything, it will go richer (same amount of fuel, less air through the motor).
Cool, I'm glad that's confirmed. I'll get the car on a dyno to measure the A/F and compare it to the original tuned graph
A little rich should be fine, better than leaning out. As long as it's still in a good spot. The car is my DD so I just want to make sure she's stable. Thanks
Originally Posted by baller status
If you have O2 feedback enabled then no, you have nothing to worry about.
However I'm sure you already know this.
blk_db2
Dec 7, 2004 11:35 PM
Used2beAb16
Aug 10, 2004 05:41 AM
2000vsm
Oct 26, 2003 08:20 PM
