B20 VTEC........
Hey guys...I just wanna make sure before I go buying this...I was gonna throw and LS VTEC in my 97 EK but i think ima go with a B20 VTEC, its the same concept as LS VTEC just with a B20 Block right? Which would be better?
searching helps
ls vtec: https://honda-tech.com/zerothread/1923227
you'll have gobs of tq either way
you can use a 99-00 si harness...that would work. or ****...even a 96-00 civic ex harness should work as long as it has the knock sensor, 4 wire o2, and of course...mad vtakkkk plugs yo. if you have those things you should be set. IMO you should convert it to obd1 and get it chipped for the b20/vtec. no stock ecu is gonna run this as well as something custom chipped specifically for it.
