OT: Anybody have any problems with scraping the DC JDM HEADER on their ITR?
I have an 01 Integra Type R and I was wondering if anybody has had any problems with scraping the DC JDM Header on their ITR? My car is lowered and I was thinking of buying the DC JDM Header, just want to get some info. on ground clearance issues before I do.
couple of guy here have had probs with hitting and one guy has gone threw like 3 of them
but if you car is stock I dont see that big of a problem
At stock height you shouldn't have any problems with ground clearance
Here's a thread I found with the SEARCH
hehe: https://honda-tech.com/zerothread?id=220671
If your car is lowered, don't get the DC JDM. I have seen a lot of them with two huge dents on the lower pipes. Go OEM JDM 4-1 instead or any JDM 4-2-1 header (= expensive). The DC sits about 2 cm (bit less than 1 inch) below the oil pan!!!!
Does anybody have a picture of the DC JDM Header from underneath the car? So I can see how much the header hangs down.
look at the thread I posted above
No, not your imagination. You need the 3D analysis program version 1.2 or newer in your brain. After running version 2 in my brain, the result is 2 cm +/- 0.5 cm.
The error in the result will be reduced in version 3....
you could go JDM 4-1 with the long skidplate.. that way you won't have to worry so much..
what size collecter does the oem jdm header have
ImportechPerformance
20
Sep 29, 2002 06:03 PM
PYITR821
Jul 5, 2002 04:52 PM
Apex i ITR
Oct 26, 2001 09:19 PM
