SWEAKY REAR
Old Nov 12, 2008 | 09:24 AM
MIGPA26's Avatar
Default SQUEAKY REAR
The rear of my hatch is sweaky.. I would push up and down and would sweak.. Is this noise the lower control arms?
any help would be greatly appriciated...
Modified by MIGPA26 at 1:07 PM 11/14/2008
Old Nov 12, 2008 | 10:06 AM
CRX Toad's Avatar
Default Re: SWEAKY REAR (MIGPA26)
My rear is squeaky when I eat beans or Latin American food.
Okay I'll be serious...what kind of bushing do you have in the car? And where exactly is the squeak coming from?
Old Nov 12, 2008 | 11:39 AM
Gotrek's Avatar
Default Re: SWEAKY REAR (CRX Toad)
if all the bushings look ok and you've lubed them and it still squeaks check your struts. I had a bad squeak coming from my front end and after lubing everything I inspected the shocks closer and found that the metal part of the shock that slides over the shock body during compression had gotten bent and was rubbing on the shocks body.
I pried it back and the squeak went away.
Old Nov 12, 2008 | 01:25 PM
SIred91's Avatar
Rainman
Default Re: SWEAKY REAR (Gotrek)
WTF is a "SWEAK"?
Old Nov 12, 2008 | 09:47 PM
traxxasx's Avatar
Old Nov 12, 2008 | 10:05 PM
acmoc's Avatar
I just fixed this, I saw it on here too, but the diy isn't here anymore.
if you have a crx, you can buy some wax, and put it on the hatch hook thing. Fixed
no more squeaks
Old Nov 13, 2008 | 03:51 PM
missa's Avatar
Default Re: SWEAKY REAR (acmoc)
it might be your trailing arm bushings?
Old Nov 13, 2008 | 04:19 PM
Tyson's Avatar
no more squeaks
yeah, most likely the "hatch hook thing". i wrap it with a plastic bag to keep it tight.
Old Nov 13, 2008 | 04:23 PM
SIred91's Avatar
Rainman
Default Re: SWEAKY REAR (Tyson)
LOL, I use a piece 0f brown paper sack
Old Nov 13, 2008 | 04:34 PM
CRX Toad's Avatar
Default Re: SWEAKY REAR (SIred91)
Electrical tape for me!
Old Nov 13, 2008 | 05:21 PM
SIred91's Avatar
Rainman
Epic. Honda. Tuning. Tech.
Old Nov 14, 2008 | 12:08 PM
MIGPA26's Avatar
ITS A 91 HATCHBACK SI..
EVERYTHING IN THE REAR IS STOCK EXCEPT FOR THE SPRINGS LOWERED TO 2.25"
Old Nov 14, 2008 | 01:22 PM
Tyson's Avatar
/subscribe
Jizzmaster Zero
19
Oct 22, 2018 10:39 AM
acanby
Jul 10, 2011 08:01 AM
danielblushtein
Suspension & Brakes
20
Nov 5, 2010 03:51 PM
randomtask77
10
Apr 29, 2010 12:34 PM
twinloop
Jan 2, 2007 11:21 AM
