Lighting HID/Xenon kits, Retrofits and Associated Topics
Issues with wiring OEM style eBay Fogs
Old Nov 12, 2008 | 08:50 AM
Nighthawk7thGen's Avatar
Default Issues with wiring OEM style eBay Fogs
Just got my yellow-lens Fog light set yesterday to replace my old, broken and long since removed clear ebay fogs for my 2001 Civic.
Now im running into issues with the wiring (since the original wiring from the 1st set has been removed a long time ago).
I followed this DIY exactly: http://www.civicforums.com/for....html
Im having issues trying to figure out why the whole unit is not getting power and all fuses have been check and are good.
Should I just hardwire them on a switch w/o a relay?
Modified by Nighthawk7thGen at 12:56 PM 11/12/2008
Old Nov 12, 2008 | 11:01 AM
CarbonizedDX's Avatar
Default Re: Issues with wiring OEM style eBay Fogs (Nighthawk7thGen)
I think you ment THIS link, the one you posted is for blue led gauge conversions...
Okay are the grounds properly connected? As well as have you tested the positive input actually having power... it's hard to tell with the write up (I don't own a 7th gen) but it seems like there is something missing...
Old Nov 16, 2008 | 05:42 AM
chickenwing's Avatar
i would not hardwire lights to just a switch.
the switch would most likely overheat and melt.
just my 2 cents but you can do what you want with your car.
Old Nov 16, 2008 | 02:28 PM
bpr0422's Avatar
ebay fogs? https://honda-tech.com/zerothread/1812043
do not wire it directly to the switch, switch would probably melt.
HondaGSX
Jul 22, 2013 07:38 PM
kseriesnet
Acura TSX
Nov 2, 2010 12:01 AM
Jdmcivicb16a2
16
Jan 30, 2010 10:56 AM
Sir_CCord
Aug 16, 2007 08:29 AM
nasirjones9mm
Jun 12, 2006 05:53 PM
