H22A4 rebuild
I have done extensive research in the archives, but I have not found the exact answers I am looking for. I am rebuilding my motor because I have most likely blown two piston rings.
- I am using Darton sleeves (I called Darton and they said the H22A4 is a solid closed deck, but I read someones thread in the archieve, and they said the A1 is closed and the A4 is closed). What's right?
- I have a turbo application and would like to run between 12-15 psi with a T3/T04 (320-350whp). I have been auto crossing but would like to get into road course racing. What would be the best compression ratio when looking for forged pistons? I want low end and top end power.
- I don't want to create a lot of work for the machine shop and create a bigger hole in my pocket. Is it worth getting larger bore pistons or longer connecting rods to increase the stroke? I don't want to mess with the crank. I am just planning on replacing the connecting rods and pistons and adding sleeves. Do I need anything else besides replacing OEM gaskets if I am just building the bottom end?
Sorry this was long - I appreciate any feedback
Modified by rags00prelude22 at 5:24 PM 11/12/2008
Modified by rags00prelude22 at 9:16 PM 11/12/2008
-a1 is closed, a4 is open
-350whp is waay too much power for tracking in a fwd car. 300whp is way to high on street tires too.
-You'd do yourself a lot of good to put the money towards seat time before you start modifying the car a lot. Starting out with that much power will tremendously slow your progress in becoming a good driver.
-Sleeving is a waste of money for only 300whp(which is too much power anyway). Use the Mahle Goldseries pistons. They're forged and will work in FRM.
I have to sleeve it because I have 140k miles on the block. The machinist said that the block would most likely not meet the correct clearance standards, and I would have blow by thus loss of compression. I have been making 300 whp for the past 4 years with stock internals, and I have been successful on the track. I understand the value of track time, and I will be running conservative boost while learning on the track.
I don't think the Mahle Goldseries will work well with sleeves.
So what piston ratio would be good to use?
I will check with the machine shop and compare the price differences between sleeving and just machining the FRM.
Thank you for your help - what compression pistons should I use? Should I lower the compression ratio using a thicker cosmetic head gasket too?
TurboGSR96
Feb 22, 2006 05:48 PM
