weight and rims
Old Nov 11, 2008 | 10:08 PM
parkerjamison's Avatar
Default weight and rims
would 17 pound rims effect the cars performance compared to stock gsr blades?
Old Nov 11, 2008 | 10:24 PM
racebum's Avatar
Default Re: weight and rims (parkerjamison)
17 isn't that bad. do you have some ultra light 17s? combined weight with the tire you run is also more important that just wheel weight. for example, some 205 50 15s weigh more than the 205 40 16 for sure and also more than some 205 40 17s. it's easier to hit low weight goals with 15s but you can do it with 17s if you spend a lot. i have a set of rays 17s that only weigh 17lbs myself. they are also wrapped with BFG KD tires and grip pretty hard.
Old Nov 11, 2008 | 11:22 PM
majinsoftware's Avatar
any extra weight on the wheels is going to affect performance, What you need to do is decide weather the wider/bigger tires give more benefits then negatives.
I run 17's with 22kg per rim, But they are nice and wide so its a fair comprise.
Old Nov 12, 2008 | 03:49 AM
ac_attak's Avatar
Default Re: (majinsoftware)
Must ride like a tank!
Old Nov 12, 2008 | 03:59 AM
nope rides fine. most the weigh on them tho is from the 225/50/17 semi slicks. just get rubbing probems on the rear over big bumps.
Old Nov 12, 2008 | 04:20 AM
ac_attak's Avatar
Why such massive tires? Way to big for an integra..
Old Nov 12, 2008 | 05:39 AM
thabao's Avatar
why is everyone talking about 17" rims? he asked about 17POUND! rims compared to blades.
your answer is that the blades weight from 15-16 pounds. so your going to have an extra 6-8 pounds with the new rims. unless you are all into dragging or auto-x. it's not that bad of a gain in wieght.
Old Nov 12, 2008 | 07:45 AM
Thank you
The wheels I do wanna get are motegi hyperblack, I think that's the name I'll post a link when I get home. They are 17's and weigh 17 pounds. What do you think, good or no.
Old Nov 12, 2008 | 10:18 AM
thabao's Avatar
sounds pretty good. the buddy clubs i have are 16" and are only 13 pounds. it all depends on what the rim is made for. but yeah 17 pound is good for a 17" rim. my prelude rims on my accord that are 15x6.5 are 22 pounds ha
Modified by thabao at 11:38 AM 11/12/2008
allanonjj
Jun 14, 2005 10:17 AM
SixguN
Feb 3, 2005 08:46 PM
iwannaboostmyteg
Mar 28, 2004 02:17 AM
lewylou
Jan 20, 2003 10:25 AM
RedRacer
Feb 4, 2002 10:14 PM
