a/c belt wtf?
im trying to take the belt out but i just found out the motor mount is in the way.
so if i take the motor mount off do i have to put a jack under the motor for support or the other 2 motor mount should hold it?
are you [freak]ing kidding me.
please learn some common sense. and for the love of christ, PAY ATTENTION. you posted because you didnt LOOK AT WHAT YOU WERE DOING.
Replacing belts on my 94 Civic requires removing 2 motor mount bolts, then jacking up the engine enough to slip the belts between the mount & frame to mount them on their respective pulleys.
Only the A/C belt passes around the front left torque mount. The alternator and P/S belts can be removed and replaced without any additional efforts.
I posted to help OP with r&r of belt(s) that requires a workaround of the motor mount, not those that don't. If it doesn't apply to a belt, then obs it doesn't apply. I don't think saying a plural 'belts' by mistake diminished the instruction I provided.
I've replaced the compressor several times & always changed out all the belts at the same time time, so for me 'changing the belts' always requires messing with the engine mount. I'm aware the PS belt doesn't require working around the engine mount. It didn't matter to me if only the compressor or the alternator- or both- required slipping a belt between the frame & mount or not. I don't assume every engine or configuration in every yr model is set up exactly the same as mine anyway.
FYI, I posted my comment while waiting for my spouse to get an MRI done at the hospital. She finished & was rushing me to drive her home. I posted in haste instead of blowing it off & not offering any help at all. I didn't reread & edit to satisfy a perfect standard because there's more going on in my life than posting to help strangers in a DIY forum.
BluTeggy
May 29, 2009 04:59 PM
PYITR821
Jun 25, 2002 11:30 PM
