replacing the ball joint/stem on hub 1990 hatchback
Old Nov 11, 2008 | 09:52 AM
90goldenhatch's Avatar
Default replacing the ball joint/stem on hub 1990 hatchback
o na 1990 civic hatchback, the ball joint thats attched to the hub...that connects to the control arm is giving me problems.
when i try to tighten the nut on the stem of the ball joint...the whole stem turns.
do i need to relace the balljoint? and how do i replace it?
thanks
Old Nov 11, 2008 | 10:19 AM
misha's Avatar
Default Re: replacing the ball joint/stem on hub 1990 hatchback (90goldenhatch)
stock joint at the moment?
Old Nov 11, 2008 | 11:07 AM
jlicrx's Avatar
you don't need to replace it - put the nut on - place a pry bar (or similar) between knuckle and lower control arm and pry up on the knuckle while prying down on the control arm (like you are trying to separate them) to place tension on the stem - this should hold it in place while you tighten the nut - a lot easier with air tools
Old Nov 11, 2008 | 01:12 PM
CRX Toad's Avatar
Default Re: replacing the ball joint/stem on hub 1990 hatchback (jlicrx)
Listen to the man he knows what he is saying.
xChrizcrozzx
38
Dec 9, 2016 10:34 AM
unclematt
12
Jun 2, 2016 04:31 AM
vbspec
11
Jun 30, 2010 10:10 AM
91blackEF
Jan 4, 2009 01:31 PM
DaChoZn1
Sep 18, 2005 03:34 PM
