Modifying Distributor from D15B8 to work on D16Z6
Old Nov 11, 2008 | 07:20 AM
buildernick's Avatar
Default Modifying Distributor from D15B8 to work on D16Z6
Basically I'm swapping my engine in one city, but I forgot my new distributor in another city, and in order to get that distributor I need to drive there. Would it be possible to mount the old distributor on the new engine even though only two of the three mounting bolts line up? I just need to have it on there for about an hour.
so
D15B8 Distributor -> mounted to D16Z6 Engine
based on this thread:
https://honda-tech.com/zerothread?id=2410576
the only difference is the mounting flange
thanks
Old Nov 11, 2008 | 09:29 AM
94EG8's Avatar
Seagull Management
Default Re: Modifying Distributor from D15B8 to work on D16Z6 (buildernick)
Yes, but i'm not even sure if 2 bolts line up. I've seen people use tywaps/plastic zip ties before. And i've personally used vice grips to hold a D15B7 distributor on a DOHC ZC to try it while waiting for a distributor. Basically as long as you can get it held on there reasonably securely you'll be fine.
Old Nov 11, 2008 | 08:38 PM
Thanks, I'm gonna try it tomorrow
95civicLS
May 5, 2010 08:13 AM
harley06
Oct 31, 2006 02:30 PM
incognitoracerr
Sep 15, 2003 03:04 PM
HarryB
Aug 13, 2002 09:13 AM
