anybody using the turbo xs quad stage boost controller?
I was just wondering who is using the quad stage boost controller and also how you guys have it connected.
I will be pushing around 750 and 800hp if the motor holds. I was thinking about using that boost controller and also if somebody has any better sugestions.
if i used quad stage bc can I use it with switches for each stage of boost or what is the best way to do it.
why not just buy an MSD boost controller? They are great, and cheap. probably one of the best controllers on the market.
MSD Boost controller is great, can be a little tricky to get setup correctly. We still run the Quad Stage turboXS on the cobalt with the MSD Timer. Plain and simple, it works.
Like they said MSD is good once setup right it works awesome and flawless. But i have yet to see anyone use one without CO2 successfully. With CO2 nothing beats it and for the price even better. Data logs itself also
we used one (msd controller) on joels car years ago without C02, worked well but I didnt have a lot of time on it or the car. PT71GTS with only one Turbonetics Racegate, min boost was 28 psi (not the controllers fault) might have had something to do with it. hot rod spec car so it hooked it anyway.
GoldieWang
Jul 31, 2016 04:15 PM
traction issuez
Apr 25, 2007 04:38 PM
Boltz
Mar 26, 2005 09:49 AM
