Need Help with codes please
Old Nov 10, 2008 | 12:01 PM
Mill-Town's Avatar
Default Need Help with codes please
So after getting my b16 in the car and starting it I got a swamp of codes.
code 3: Map
code 6 Water Temp Sensor
code 7: TPS
code10: Intake Air Temp
Everything is pluged in and it all worked fine before replacing the bottom end. Now all of a sudden I get all these code. I replaced the Water temp sensor in the thermostat houseing and nothing happened, And the gauge still doesnt work. When I unplugged the MAP the Car still ran, Same when I unplugged the TPS (With car running)
Ideas please?
Old Nov 10, 2008 | 02:40 PM
Mill-Town's Avatar
Default Re: Need Help with codes please (Mill-Town)
Some one has to know why all these things would go off at once?
Old Nov 10, 2008 | 04:08 PM
Mill-Town's Avatar
Old Nov 10, 2008 | 04:11 PM
wrenchez81's Avatar
you may have some connectors swapped!!!!
Old Nov 10, 2008 | 04:13 PM
Mill-Town's Avatar
Default Re: Need Help with codes please (wrenchez81)
next....
Old Nov 10, 2008 | 04:18 PM
mikehawk's Avatar
reset the ecu ....
undo the neg cable turn the key on like you are going to start it and hold it for 10 secs reconnect the battery, start the car .. see if they come back.
Old Nov 10, 2008 | 04:44 PM
Mill-Town's Avatar
Default Re: Need Help with codes please (mikehawk)
Originally Posted by mikehawk
reset the ecu ....
I suppose I could try that, The step I took was: Pull the Ecu fuse, un did the neg cable, waited 10 mins and reconnected then started
Old Nov 10, 2008 | 04:52 PM
mikehawk's Avatar
there are several ways to do it ... gl
Old Nov 10, 2008 | 05:41 PM
Mill-Town's Avatar
Im just trying to figure out what could trigger all these codes at once?
Old Nov 10, 2008 | 08:48 PM
Mill-Town's Avatar
Old Nov 11, 2008 | 11:16 AM
Mill-Town's Avatar
bump for more Ideas
Old Nov 11, 2008 | 02:29 PM
Mill-Town's Avatar
Old Nov 11, 2008 | 02:44 PM
ZombieFerio's Avatar
I have some ideas.. They all have to do with you...
Old Nov 11, 2008 | 02:53 PM
Mill-Town's Avatar
Default Re: Need Help with codes please (ZombieFerio)
Lol wow this from a trial member...
Old Nov 11, 2008 | 02:57 PM
Preferio's Avatar
Yeah, I know, right?
::reference usernames::
Old Nov 11, 2008 | 03:00 PM
CTR_B's Avatar
Default Re: Need Help with codes please (Preferio)
Old Nov 11, 2008 | 03:02 PM
Preferio's Avatar
Default Re: Need Help with codes please (CTR_B)
Originally Posted by CTR_B
Do I know you from GDD? The place 'I have been bannished from... The horror...the horror...
Old Nov 11, 2008 | 03:04 PM
Mill-Town's Avatar
I don't know, Do you?
Old Nov 11, 2008 | 04:33 PM
mikehawk's Avatar
guessing resetting didnt work??
Old Nov 11, 2008 | 04:41 PM
Mill-Town's Avatar
No resetting it didnt do the trick. As far as I know all the connectors are in the right places.
Old Nov 11, 2008 | 04:42 PM
mikehawk's Avatar
replace the **** thats broke then
Old Nov 11, 2008 | 04:58 PM
Mill-Town's Avatar
Lol I don't see how all those things go bad at once?
Old Nov 11, 2008 | 05:17 PM
mortificationrock's Avatar
Well first of all you might have switched the map and tps plugs. Check that....and as far as the ECT sensor its in the head. The one you replaced was the fan switch.
Old Nov 11, 2008 | 05:40 PM
Mill-Town's Avatar
Default Re: Need Help with codes please (mortificationrock)
Which one controls the temp gauge?.. I tried switching them but I will do it again just to double check
Old Nov 11, 2008 | 06:07 PM
the gauge one is a 1 wire sensor in the head below dizzy
