Help needed for h22a swap in a EG8
Old Nov 10, 2008 | 09:02 AM
EF9_TryMe's Avatar
Default Help needed for h22a swap in a EG8
I got a 4 door 94 eg, and I just want to know what all do I need if I have the H22a. I got the H22a, with the prelude tranny it'self. The motor is obd1, I have the intake manifold with it ... no midshafts or axles though, just wondering all the stuff what I need ?
Old Nov 10, 2008 | 10:08 AM
slo_hatch's Avatar
Default Re: Help needed for h22a swap in a EG8 (EF9_TryMe)
so your asking what you need to do a h22 swap in your sol?
Old Nov 10, 2008 | 06:14 PM
CivicSpoon's Avatar
EG8 is a Civic 4dr, not a Del Sol.
You should do a search for info on this swap, it's been covered many times before. But here are a couple links from the FAQ page (you should always check that first, in addition to searching, before asking questions):
https://honda-tech.com/zerothread?id=650329
https://honda-tech.com/zerothread?id=434668 - Axle Info
Old Nov 10, 2008 | 06:58 PM
z6hatchboy's Avatar
As mentioned you need to research. However for a h22 swap you need to (quick run down): cut a square in the original shifter place for the cable shifter, get the hybrid axles, the mounts (when doing the mounts the factory passenger mount off the chassis and the new one is welded or bolted in. The alternator wiring must be extended on the h22 where is sits up front as opposed to the factory eg motor harness being in the rear. If using a usdm motor and ecu then you'll have to wire the egr system, is jdm then use a chipped p28 and your good (cause jdm dont have a egr system). Thats just a quick run down of it
Old Nov 11, 2008 | 05:45 PM
EF9_TryMe's Avatar
Okay thanks, but which shifter cable do i need to use from a bb6 or a bb4 ?
Old Nov 13, 2008 | 01:01 PM
teefunk01's Avatar
Default Re: (EF9_TryMe)
If you have any questions feel free to shoot me a pm
Mike Po
Suspension & Brakes
Oct 3, 2007 02:07 PM
lazyboy
Jul 27, 2006 05:38 PM
Plateus
Honda Civic (2001 - 2005)
Jun 12, 2006 10:40 AM
explosive
Jul 13, 2003 05:20 PM
95integragsr1984
Dec 23, 2002 01:00 AM
