usdm f23 5th gear into T2W4
Old Nov 10, 2008 | 08:52 AM
hamadiscool's Avatar
Default usdm f23 5th gear into T2W4
Old Nov 10, 2008 | 09:07 AM
A Blue Lude's Avatar
Default Re: usdm f23 5th gear into T2W4 (hamadiscool)
Shifting from 4 to 5 would be really weird. I am curious as to the feasibility of it though.
The FD shouldn't mess with anything, the VSS is "after" it.
Old Nov 10, 2008 | 04:24 PM
Giant_Bean's Avatar
I've heard of the F series 5th gears being swapped in, but I believe the gear is thicker than the H series, and requires machining to make it work.
Old Nov 10, 2008 | 11:32 PM
PreludeZ's Avatar
I am running in my 4th gen Accord type-R U2Q7 tranny with H23 M2K4 5th gear (0.757) and it is great. The H23 5th gear is 5mm wider and it has to be machined from both sides a few mils. I dont remember exactly how much from which side (machning is mot symetrical) but you will see it clearly when you pull it out of the gearbox and measure it.
I made this mod also for 5th gen M2P4 and it had to be also machined 5mils...
Old Nov 11, 2008 | 12:12 AM
PreludeZ's Avatar
it is not the teeth to be cutted, just the hub of the gear on the countershaft is wider than you need. The gear on the mainshaft is the same width and can be assembled unchanged.
Old Nov 11, 2008 | 12:28 AM
PreludeZ's Avatar
nope, I am talking about the right one. The right one is from the countershaft. The left one remains unchanged.
Modified by PreludeZ at 10:40 AM 11/11/2008
Old Nov 11, 2008 | 12:47 AM
PreludeZ's Avatar
on my picture, there is only one half of the gear, you have to mirror it to see the whole gear. It means the same as this
Old Nov 11, 2008 | 04:35 AM
PirateMcFred's Avatar
While I am not familiar with the gearbox/gears that PreludeZ is talking about he's basically stating the same things I found out about the M2S4 .812 5th gear that I wanted to put into an M2F4.
I think the best you can do is to pull both 5th gears sets out of their respective cases and see what needs to be changed, then send them to a machine shop with a surface grinder.
In my case I'll just be swapping to an M2B4 I picked up for $95 locally. Yay .787 5th but with the 1-4th of the M2F4.
Old Nov 11, 2008 | 05:29 AM
PreludeZ's Avatar
Default Re: usdm f23 5th gear into T2W4 (PirateMcFred)
I made it simply on turning machine
M2K4 is EDM H23A2 tranny and is slightly different from USDM M2S4:
M2K4 - 3.307 - 1.809 - 1.269 - 0.966 - 0.757 - 4.266 - P4G EDM H23A2
M2S4 - 3.307 - 1.857 - 1.320 - 1.034 - 0.812 - 4.266 - P4G USDM H23A1
I have collected all tranny ratios here: http://forum.honda-club.cz/viewtopic.php?t=5959
Old Nov 11, 2008 | 07:50 AM
Default Re: usdm f23 5th gear into T2W4 (PreludeZ)
The last guy that tried to turn down a 5th gear on a lathe had issues and resorted to a surface grinder to get the proper thickness. I don't know if he tried to use HSS or carbide tooling though. Carbide will cut some hard stuff.
Old Nov 11, 2008 | 12:40 PM
PreludeZ's Avatar
I used universal centre lathe (cca 1500kg baby) and of course tool with carbide plate without any problems
HSS is not good enough for material of this type class and hardening
Old Dec 18, 2010 | 08:28 PM
dl_ude's Avatar
Not sure if 5th gen prelude gearbox will work on 4th gen lude ( Cause of the speed sensor ) both of them being different
Any assistance greatly appreciated
Old Dec 19, 2010 | 12:33 PM
dl_ude's Avatar
New to the forum, successfully worked the fifth gen lude gearbox M2Z4 into the 4th gen prelude. And yes the both VSS are different. However the VSS from the 5th gen plugged in quite easily and works well, I have not removed my old Speed sensor as yet, it is just secured to the back of the engine as it still has the PS lines going to it.
I am thinking that I could just probably join those two lines but not sure. anybody has any suggestions?
Old Dec 19, 2010 | 11:03 PM
AznBlueBoy's Avatar
That is a direct bolt on.
Old Dec 20, 2010 | 04:46 AM
minilogoguy18's Avatar
Just use your old VSS.
My T2W4 came with a different one and I just used the one from my M2S4, you pretty much stick with whatever came with the car.
92eg6lsvtec
Jul 9, 2008 07:08 PM
CRXizSLAMM'd
Jul 14, 2004 05:14 PM
Duster
Feb 18, 2004 01:20 PM
kochtravis
Jun 24, 2003 11:38 AM
